I hope I'm not late for work!
Old Sep 4, 2019 | 03:24 PM
  #1911
Atomic's Avatar
I have a gauge for that
The big one on the bottom? Yes, always been there.
Old Sep 4, 2019 | 04:45 PM
  #1912
skolman91's Avatar
Alright just checking, went thru some similar trans problems recently resulting from not being able to run that cover.
thought id ask
Old Sep 6, 2019 | 11:21 PM
  #1913
1FastBrick's Avatar
Custm2500's Rude Friend
So.... Is it fixed yet???
Old Sep 7, 2019 | 12:47 AM
  #1914
Atomic's Avatar
Nope, havent even touched it and im about to be out of town for 2 weeks.
Old Sep 7, 2019 | 07:39 PM
  #1915
1FastBrick's Avatar
All the more reason to get it out and sent out for a rebuild...
Old Sep 10, 2019 | 12:25 PM
  #1916
99ta's Avatar
thought id ask
Care to elaborate on that?
Old Sep 11, 2019 | 01:06 AM
  #1917
skolman91's Avatar
Dont want to clutter up his thread so ill post more in mine, but to sum it up the dust shield on 80es are actual structural support to the case, without it case flexes and takes out the pump then clutches.
Old Sep 11, 2019 | 06:55 AM
  #1918
03sierraslt's Avatar
yep, sure can. People like to not run them though. I always run mine.
Old Sep 11, 2019 | 08:02 AM
  #1919
Atomic's Avatar
I always run mine also. I striped out the threads in the oil pan at one point ears ago so its helicoiled with 1/2" bolts now.
Old Sep 11, 2019 | 12:00 PM
  #1920
Atomic's Avatar
I figured you guys would enjoy this one, a dead idle stomp to WOT before I broke the trans, or this might have been what broke the trans actually. I turned down the controller a little bit so the turbos came in slightly slower than normal since it wasnt a prepped surface. The time scale is 10 seconds.
idle to WOT stomp
The gist is went from vacuum to 2psi before my foot made it all the way to the floor, then 8psi a half second later, and a half second after that was at 17psi or so. This was with a 10psi pulley and turbos set to 6-7psi. Lean tip in is also fixed. Spools twin s475s pretty fast!
