I hope I'm not late for work!
Old Mar 30, 2016 | 01:54 PM
  #1411
Vortec350ss's Avatar
ehhh not exactly.
For instance:
2.9/7.9= 2.72
Now lets add the .3" of diamater the ribs add on both sides of the pulley
3.2/8.2= 2.56
Old Mar 30, 2016 | 08:25 PM
  #1412
Jeebalow's Avatar
Yeah, I thought about this after I posted. Thanks for the example.
Old Mar 31, 2016 | 10:42 AM
  #1413
kbracing96's Avatar
I'll though in my 2 cents, lol. I'd wrap a belt around the pulley and then measure to the back side of the belt. That way you would have a true representation of diameter where the belt is riding in the pulley for a measurement.
And different belts can ride at different heights on the pulleys depending on construction.
Old Mar 31, 2016 | 11:04 AM
  #1414
Atomic's Avatar
I have a gauge for that
So I measured the belts I have at home, and the actual rib depth is only about 0.05", which is shallower than I was expecting, but you never want the ribs to bottom out in the pulley. I had my rib spacing about perfect from eyeballing it which I was pleased about. Overall belt thickness was about 1/8".
Old Mar 31, 2016 | 01:39 PM
  #1415
Jeebalow's Avatar
I did some reading and what you should be looking for is the pitch diameter of the pulley. It is at the fibers in the belt when it is wrapped around the pulley. So you can cut a belt and measure from the back of the belt to the fibers then subtract twice that from the diameter of the pulley with the belt wrapped around it. That should be the effective pulley diameter.
Old Mar 31, 2016 | 01:45 PM
  #1416
Atomic's Avatar
To me it would make sense to measure from the top of the ribs of the pulley, which is the same as the bottom surface of the belt. I think this is the same thing as you described. Who knew measuring a pulley was so hard!
Old Mar 31, 2016 | 01:51 PM
  #1417
Jeebalow's Avatar
Lol. Well, I don't know if the belt fibers are at the bottom surface, I would think they are somewhere in between the top of the ribs on the pulley and the smooth belt surface. The top of the ribs is probably a close enough measurement that it won't make a huge difference though. I will have to cut a belt that I have lying around and measure where the fibers are. Maybe this weekend.
Old Mar 31, 2016 | 01:55 PM
  #1418
Atomic's Avatar
I mean I measured a belt this morning, didnt have to cut it, just bend a portion back so you can see it. I measured total height of 0.125" and rib height from the bottom of the belt at 0.05", so belt thickness w/o ribs is 0.075". The valley in the pulleys best I can tell is around 0.15" or almost triple what the actual belt rib height is.
Old Mar 31, 2016 | 09:31 PM
  #1419
BlackGMC's Avatar
Resident Retard
Check out this waterpump i ran across
Wide pulley LS3 water pump - for 10 rib belt drive
Old Mar 31, 2016 | 10:25 PM
  #1420
Atomic's Avatar
Way to steal my thunder there champ
