I hope I'm not late for work!
Old Jul 31, 2015 | 10:18 AM
  #921
kbracing96's Avatar
The fix for your meth is a check valve from Devil's Own. It has a 16psi cracking pressure so it can't be opened from engine vac, but pump pressure will push it right open. That's what I used on my KB blower when I spayed pre and post rotor and post TB.
Methanol Injection Check Valve
-4 AN Check Valve : DevilsOwn Methanol Injection
Old Jul 31, 2015 | 10:50 AM
  #922
Atomic's Avatar
I have a gauge for that
Ooooo thats a good idea and would make it a lot easier! Did you notice any decrease in flow or does it flow plenty to not be a restriction? Thanks!
Old Jul 31, 2015 | 11:26 AM
  #923
kbracing96's Avatar
I didn't notice any difference in flow. I'm running the same check valve on my truck for like the last 6-7 years both with the blower and now back with the turbo. Works great and never had any issues with it. Pull the line out of the nozzle and it free flows a lot of fluid, way more then what your nozzles are restriction the flow rate too.
Old Jul 31, 2015 | 12:13 PM
  #924
BlackGMC's Avatar
Resident Retard
I used that same check valve for along time. I took it off because Julio (alky control dude) said i did not need it with his kit the way i was plumbing it.
Old Jul 31, 2015 | 08:21 PM
  #925
Atomic's Avatar
Well I went to pull the power steering pulley off to install the 8rib one and the puller freaking ripped the lip right off the pulley without it budging....so it looks like my best bet is going to be to buy another pump and just install my 8rib off the bat. Also the idler pullies look to be the wrong offset for the whipple bracket (they sit back too far). Always something.
Old Jul 31, 2015 | 08:23 PM
  #926
GMCtrk's Avatar
Always something is correct. If it's not, somethings wrong lol
Old Jul 31, 2015 | 08:43 PM
  #927
smokeshow's Avatar
Mod with training wheels
I've also ripped that lip off with the puller lol.
Old Aug 1, 2015 | 12:31 AM
  #928
Vortec350ss's Avatar
Did the kit come with any spacers? Mine did and alignment wasn't an issue using them.
Old Aug 1, 2015 | 09:27 AM
  #929
ChevyThunder17's Avatar
I've learned so much more about the Whipple since you've gotten it. I never had the time with my job being the way it is, so I'm going to be fixing that issue in the next month or so.
Old Aug 1, 2015 | 11:48 AM
  #930
BlackGMC's Avatar
Resident Retard
I had to make 1 spacer for my metco 100mm idlers.
