I hope I'm not late for work!
Old Jul 26, 2015 | 10:13 AM
  #901
silver-mod-o's Avatar
Hunt&Fisherator
Nope, everything's fine. I did the math, you're actually making 547hp at idle.
Old Jul 28, 2015 | 11:57 AM
  #902
BlackGMC's Avatar
Resident Retard
did you find your boost leak/issue?
Old Jul 28, 2015 | 12:18 PM
  #903
Atomic's Avatar
I have a gauge for that
I think the bypass actuator on the back of the blower may have a leak so its not fully closing, so I plan to take that off and dick with/replace it.
Old Jul 28, 2015 | 12:58 PM
  #904
03sierraslt's Avatar
Why is it sucking meth at idle?
Old Jul 28, 2015 | 01:16 PM
  #905
Atomic's Avatar
Vacuum behind the throttle body was pulling it through the pump and hose. Pretty substantially too. I have heard of this being an issue, but short of putting a solenoid near the nozzle I think the only work around is putting the nozzle in front of the TB. Not a huge issue just not as clean.
Old Jul 29, 2015 | 01:07 PM
  #906
Atomic's Avatar
So I took off the bypass actuator thing...the reference lines has a very small orifice in which to allow air in and out of the bellows. This makes response very slow to close the valve. I even hooked up the line to my air compressor and 60psi still takes a good second to full close. I am going to try and drill that out some and see if that helps the responsiveness, probably from a 0.005" hole to .015" or so (smallest bit I have).
Old Jul 29, 2015 | 01:19 PM
  #907
Wait so you had it after the TB? No wonder.
Old Jul 29, 2015 | 01:26 PM
  #908
DrX's Avatar
DrX
I believe that the spring closes the valve. Vacuum holds it open.
I was going to plumb my meth after the TBs as well, but that requires a solenoid which adds another potential point of failure, according to Julio(Alky Control).
Old Jul 29, 2015 | 01:44 PM
  #909
Atomic's Avatar
Yea, spring closes the valve, but the spring can only expand it as fast as air can fill it depending on the spring rate. I dont see an obvious way to take it apart and put in a heavier spring, so next option is let it get rid of the vacuum faster. If that is not satisfactory then I will reference it under the rotors instead of after the TB to be able to put positive pressure on top of it to help close it faster.
I have a meth solenoid actually, just dont really want to install it.
Old Jul 29, 2015 | 04:19 PM
  #910
BlackGMC's Avatar
Resident Retard
Interesting you found that. I saw this little thingy on Superchargersonline and kinda wondered what it did... Sounds like your doing the same thing with your whipple.
INSTA-BOOST Upgrade Insta-Boost upgrade [Mag-instaboost] - $11.00 : SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
