I hope I'm not late for work!
Old Mar 31, 2016 | 10:31 PM
  #1421
BlackGMC's Avatar
Resident Retard
Oh sorry...
Old Mar 31, 2016 | 11:42 PM
  #1422
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Atomic
Way to steal my thunder there champ
I think you mean Chump...
Old Apr 1, 2016 | 08:13 AM
  #1423
Atomic's Avatar
I have a gauge for that
Can someone with a tvs pulley measure the space from the mounting flange to the back of the pulley and from the back of the pulley to the first rib? Also the bolt hole mounting pattern. Just looking at one I wonder if it wouldnt work on a whipple...
Old Apr 1, 2016 | 08:54 AM
  #1424
03sierraslt's Avatar
I can get you whatever measurement you need when I get home Tonight
Old Apr 1, 2016 | 03:18 PM
  #1425
BlackGMC's Avatar
Resident Retard
Pm me your address and I will send you a pulley you can have.
Old Apr 7, 2016 | 12:20 PM
  #1426
Atomic's Avatar
Well so the TVS blowers have a wider base circle for the mounting bolts and a larger diameter hub bore, and the belt also sits further away from the mounting plane.
I drew this little adapter in SW that would allow mounting any tvs pulley to a whipple, in theory. Only hard part is I would need to press or weld in studs for the TVS pulley to mount on since a through hole would hit the whipple hub.
My nitrous stuff also finally got here yesterday.
Old Apr 7, 2016 | 12:53 PM
  #1427
walledition's Avatar
I know where im ordering a pulley if i ever need a stronger badass one
Old Apr 7, 2016 | 01:13 PM
  #1428
GM1697's Avatar
Whatcha get?
Old Apr 7, 2016 | 07:22 PM
  #1429
Atomic's Avatar
Spraybar spacer thing, solenoids, misc stuff, window switch. Couple issues I need to call them about tomorrow though.
Old Apr 8, 2016 | 12:57 PM
  #1430
Atomic's Avatar
So I still have faith I can get the meth system to basically hook straight up to the fuel solenoid. I attached a little spreadsheet I made to figure out the new jet size based on the pressures and areas. Good news is NX makes the jets I would need at 180psi fuel pressure, and they are going to swap them out for me when I send some fittings back.
Also finalized dimensions on my whipple to tvs adaptor. Would anyone be interested in one? Allows the use of TVS pullies on whipples.
