I hope I'm not late for work!
Old Mar 25, 2016 | 05:51 PM
  #1391
Jeebalow's Avatar
That looks really good! Can't wait to see what it does. So they bent tubing and then did some precision hole drilling for whatever size shot you asked for? How much did you ask for? What will the flow be total for each (nitrous/meth). Could you not fit 8 small nozzles with 1/8 of the total flow just above the ports for each? (They probably would have done so if they could I guess. Just curious.)
Edit- next rev could have the blocks that hold the tubes machined into it. They could machine 2 grooves at 2 depths with a ballnose and then they would just need to be held in place. I am thinking a mating part with a small screw or something. Good work!
Old Mar 25, 2016 | 06:36 PM
  #1392
Atomic's Avatar
I have a gauge for that
Yea, could have done indiviual ports but that would have been a lot more expensive and a lot more parts, this is fairly simple with just 1 nitrous and 1 fuel connection point. I told them I wanted a 250hp shot with alcohol, so the fuel holes are about twice as large as gas. Not sure how much total this spacer could support with a big enough jet in the front, more than I want to run probably.
I didnt know they were going to use those blocks, looks like that just tig'd it on there. The spacer is essentially a 2D part; maching the groove for the oring was a job in itself. If I make any more the whole thing will be CNC.
Old Mar 25, 2016 | 06:45 PM
  #1393
Jeebalow's Avatar
Oh I see, so you just jet the connection point for whatever size shot/alcohol flow you want. Which, if I'm understanding correctly means that your upper limit for shot size is the tube holes and lower limit is the jet?
Yeah, it does look like they TIG'd them. I was saying you could just have those blocks left on there already if you do make more and have it CNC'd. Lol, I was assuming you will be making more. I am interested and madmann just got his whipple installed too so I'm sure there could be interest there as well. If not for the nitrous side of it, for the post rotor/direct port meth injection part of it.
Old Mar 26, 2016 | 01:23 AM
  #1394
Vortec350ss's Avatar
Looks awesome Richard!
Old Mar 29, 2016 | 03:55 PM
  #1395
Atomic's Avatar
Well on todays episode of what did he draw I made a 8rib whipple pulley with some minor tweaks. I doubled the thickness of the mounting flange and also made it 1/8" deeper to sit more over the top of the hub so there isnt as much bending stress on it. Cutouts also reduced in size to make it a little stronger. The diameter as shown is 2.7".
Old Mar 29, 2016 | 04:53 PM
  #1396
03sierraslt's Avatar
Be careful over spinning a twins crew.
Old Mar 29, 2016 | 05:16 PM
  #1397
Atomic's Avatar
Care to elaborate?
The 2.7 should put it at max speed near the shift since the crank pulley is smaller than I thought.
Old Mar 29, 2016 | 05:39 PM
  #1398
TXsilverado's Avatar
Originally Posted by Atomic
Why not let the pump eat and let it go at 150psi and just jet down so it flows what I need it to? I can have the pump turn on at 0psi and/or an rpm range. I can have it come on before the nitrous so it has a chance to prime the line before the solenoid
the fuel jet would be tiny to hold back 150 psi. tiny holes are more likely to become stopped up with gunk/trash. fuel jets that are stopped up make really loud bangs. this is part of the reason that stand alone fuel systems are typically built as a 5psi setup. larger jets are less likely to get plugged, and it also open your tuning window having a regulator inline. instead of jet changes, you can adjust fuel pressure for the fine tweaks.
Old Mar 29, 2016 | 08:31 PM
  #1399
Atomic's Avatar
Thanks for the input. With meth though it is going to need about double the flow of gas, so that will naturally be a larger jet. I dont know exactly what the pump pressure will be, but at 200psi the jet will flow exactly double what it does at 50psi. So it may end up being a normal gas size jet after all, but obviously I plan on doing a lot of bench testing on this.
There is a filter on the meth feed line, but point taken. I also got a filter for the nitrous line.
Good point about tuning with fuel pressure as opposed to jets. At 150-200psi it becomes relatively insensitive to pressure changes because its so high. A good thing about meth is the tuning window is huge compared to gas. You can massively over fuel with alcohol and it will still run and not loose much power or misfire.
I bought a 150psi normally open pressure switch from amazon I am going to use a fuel safety switch. I think I can use the test button to prime the system so theres no air.
The spray bars will do a 300hp shot max, after that the holes would need to be resized to flow more. The fuel holes are already sized for meth.
Old Mar 29, 2016 | 08:33 PM
  #1400
What size crank pulley and shift RPM. Last I knew the key speed for the whipple was 18k.
