I hope I'm not late for work!
Old Mar 29, 2016 | 08:49 PM
  #1401
Atomic's Avatar
I have a gauge for that
Crank is the IW OD pulley, which I measured as 7.9". Shift RPM is whatever, but with a 2.7" pulley it hits 18k at 6150rpm which is close to where I would like to shift. Whipple lists the continuous and max rpm as the same, which sounds conservative to me, im sure 18,500 (6300ish) wouldnt be a big deal.
Old Mar 29, 2016 | 08:57 PM
  #1402
03sierraslt's Avatar
So your 10% OD pulley is only a 3% really?
Old Mar 29, 2016 | 09:12 PM
  #1403
Atomic's Avatar
No, I measured the stook pulley to be 7.24 so 9.1% OD.
Old Mar 30, 2016 | 09:36 AM
  #1404
Vortec350ss's Avatar
How did you measure it?
Old Mar 30, 2016 | 10:06 AM
  #1405
Atomic's Avatar
With a bigass set of calipers, and a second way by measuring the circumference with a string and dividing by pi. Pretty sure we had this conversion however many months ago when I did it
Old Mar 30, 2016 | 10:18 AM
  #1406
We did yea... i remembered you saying calipers but I couldnt remember where exactly you measured to. In the grooves or on top of the ribs.
A string will be in the groove as well. One of these days I am going to cut up an old belt to measure the circumference.
Old Mar 30, 2016 | 10:24 AM
  #1407
Atomic's Avatar
Best I can figure, pullies are measured at the bottom of the groove. Although on a pulley larger than a few inches it wont really matter. The groove depth I think is around 0.15".
Old Mar 30, 2016 | 10:28 AM
  #1408
Which when adding .30" it lands you squarely on the factory claimed diameter and the 8.25 it takes to be 10% OD... hmmm.
Sounds like they should be measured from the top of the groove. I guess that makes sense... you dont measure tire height from the depth of the tread.
Old Mar 30, 2016 | 10:35 AM
  #1409
Atomic's Avatar
I thought the same thing, but all my blower pullies seem to be measured from the bottom of the groove to match what is stamped on them.
Old Mar 30, 2016 | 01:45 PM
  #1410
Jeebalow's Avatar
Does it matter where you measure as long as you measure both the crank and blower pulley the same? It's just a ratio right?
