Back in the game. RCSB 1500 D-max swap coming...
Old May 25, 2013 | 02:04 PM
  #351
thunder550's Avatar
High on diesel fumes
It's actually riding quite a bit better after I removed the bump stop mounting bracket per Roger's recommendation. I'm debating now whether I should bother removing a spring or not. Either way, I already ordered to Caltracs, so that's what I'm going with, lol.
If I do decide to remove a spring I'll pull the center one as silver-mod-o recommended above. If I don't [pull a spring, I'll have to buy a longer spring pin to go through the 4* shims. Will the Caltracs raise the back end at all?
Old May 25, 2013 | 02:07 PM
  #352
Atomic's Avatar
I have a gauge for that
Most auto part stores have those spring pins for like $7 and are 6" or so long.
Old May 25, 2013 | 02:21 PM
  #353
AKlowriderZ71's Avatar
11 Second Hall Moniter
Chris, you'll need new center bolts for your leaf packs no matter what. The old ones often break. Even in they don't break, they'll be rusted really bad & you won't want to re-use them. If you have a spring shop near you, stop by and see if they have bolts with taller pins. You'll need a taller pin or it will not reach through your 4* shim and still have enough to reach into your spring perch on the axle. If they don't have the bolts with taller pins, then ask them for some spacers. I have some spacers here that I can mail to you if needed.
About Cal-Tracs & removing leafs. The overload leaf is the one I usually remove with Cal-Tracs. If you leave it on, it seems like the overload hits the bar. I don't have a pic to show you what I'm talking about... Anyways, that's just been my experience with them. I have 4 or 5 trucks set up this way, including my 1500, and no complaints about ride quality from anybody. I think proper preload of the bars is key here.
You need very little preload. Too much WILL raise the rear of the truck. Once the bar is touching the top of the leaf spring, crank the bar 1/2 to 3/4 turn tighter, then lock the jam-nuts. I'd start with 1/2 turn of preload and see how it acts.
Old May 25, 2013 | 04:29 PM
  #354
s/c'd cav's Avatar
Originally Posted by thunder550
Oh I got something for you.....
dont let the wifey know , lmao
Old May 25, 2013 | 07:18 PM
  #355
thunder550's Avatar
Thanks for the info. If I pull a spring I know it will drop the rear of the truck a little bit, but the shim should be a small increase as well...I just wonder how much it will drop. I have some room to drop the t-bars up from some more, but I'm not sure how much room is left in the alignment. I guess I'll just have to try it and see what happens.
I'll check the Napa up the street from me.
I found a 60hp tune over on DP that a member made that had good reviews, thinking about loading it up. Shouldn't be enough to hurt the trans or anything.
Old May 26, 2013 | 10:28 AM
  #356
Quyonmob's Avatar
Building the diesel fueled toy GM should have made!
Old May 26, 2013 | 12:06 PM
  #357
thunder550's Avatar
I just loaded up a 40hp tune that a member over on DieselPlace made, that woke it up quite a bit. Can't wait to get the trans built and really let loose!
Old May 26, 2013 | 08:28 PM
  #358
thunder550's Avatar
Tie rod sleeves installed
Old May 27, 2013 | 08:28 AM
  #359
mwalls54's Avatar
Need More N2O Mod
Why dont you clean it? It probably has 5lb of grease on it
Old May 27, 2013 | 11:26 AM
  #360
thunder550's Avatar
Grease = slick. Slick = less friction. Less friction = less drag. Less drag = faster. Therefore, we can deduce that Grease = Faster, and extending that theory, More Grease = More Faster. Duh
