Back in the game. RCSB 1500 D-max swap coming...
#603
This isn't my photo, but my installation is the same. I'm running this filter as a secondary to the OEM, that's the configuration Kennedy recommends.
#604
Pump location
Lines. I already had the steel braided section since I shortened the factory hard lines.
Fuel sender changes. The large line on the right used to be the tank vent, and is now the feed line. I swapped the tank vent over to the original smaller feed line.
Kennedy's control harness is pretty slick. The main control box mounts under the hood. It has a momentary button on it for manual pump activation, which is really handy when bleeding fuel filters. No more pumping the stock filter head to prime everything. It also has an ignition on sense wire that runs the pumps for a few seconds when the ignition is first switched to run, much like the gas vehicles do. The main on/off switch actually comes from an oil pressure sensor, so the fuel pumps will only run when the engine is actually on.
Oil pressure sensor above the oil filter.
Here's the mega filter head
Looking up from between the bumper and tire on the passenger side.
#608
SLOPONY
20
10-18-2016 06:05 AM
FlowmasterMufflers
07-17-2015 03:26 PM
FlowmasterMufflers
07-09-2015 11:35 AM
