injector size question
Old Jan 30, 2008 | 09:51 PM
joshua022's Avatar
Default injector size question
I'm in the process of picking out the heads for my 5.3 H/C build. and I was wondering how do you know what size injectors i will need.
I'm looking at the ET performance 215cc heads and the AFR 205s. I noticed closet redneck is running 48lbers on his 5.3.
What are the biggest "plug and play" injectors for our trucks?? marine 8.1s??
I would like to stay plug and play, but if I need to, I can re-wire the connectors.
Thanks
-Joshua
Old Jan 30, 2008 | 10:05 PM
jakebdb56's Avatar
Thanks
-Joshua
I'm in need of the same info. Right now I'm at 98%IDC with just the cam . I'm wanting to go nitrous so adding the walbro and injectors is the next step. I've heard the 8.1's are good, but would like to hear from someone with experience with running the 8.1's
Jake
Old Jan 30, 2008 | 10:08 PM
dirt track racer 81's Avatar
48's are too big..im running 28s on my 6.0..ive also raised my fuel pressure
Old Jan 30, 2008 | 10:09 PM
quicksilverado's Avatar
The 8.1 Marine injectors will take you as far as the 5.3 will go n/a. I will have a set available in a couple of weeks.
Old Jan 31, 2008 | 07:23 AM
joshua022's Avatar
I was thinking the stock 8.1s would be a little too small for how good either of these heads I'm looking at are. Are there any around a 36ish size that are plug and play?
Aren't the 8.1 marine injectors 42lbs??
Old Jan 31, 2008 | 07:50 AM
truckmann's Avatar
Stock 8.1 are ~31#, I believe the flex fuel injectors are ~36#
Yes and they are also plug and play.
All require a little adjustment in the tune of course.
Old Jan 31, 2008 | 11:02 AM
Thunder2002's Avatar
Default Injector size question
The 8.1 injectors (delphi marine) are 42 #. I am running those in my 5.3 with Whipple supercharger, LS6 cam and Edelbrock CNC heads. Weren't plug and play though, had to put a re-tune on to compensate. Just a bit too rich....
Old Jan 31, 2008 | 11:06 AM
TXsilverado's Avatar
im on the smaller 8.1's. 5.7 liter heads and cam with full bolt ons. im sitting at 96% duty cycle. the small 8.1's should handle the 5.3 perfect
Old Jan 31, 2008 | 11:28 AM
joshua022's Avatar
Even with the really good flowing heads??the lil 8.1s will be enough??
I wish I wouldn't have just sold my set of the little 8.1s then.
Old Jan 31, 2008 | 11:31 AM
i would think so. im on patriot stage 2 ls6 heads with a 226 cam and more cubes and the smaller 8.1 are holding strong.
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
bsn1989
Jul 16, 2015 08:20 AM
jrplz
Jul 9, 2015 12:07 AM
