6.0 bored .040 over
Old Jul 31, 2015 | 11:11 AM
USMCvet0311's Avatar
Default 6.0 bored .040 over
Question is what would my cubic inches be? Stock stroke just .040 over.
Old Jul 31, 2015 | 04:33 PM
Any idea?
Old Jul 31, 2015 | 04:51 PM
Mr. Chainsaw's Avatar
370-371?
Old Jul 31, 2015 | 05:19 PM
.030 over is a 370 so I'm guessing a 371 or 372.
Old Jul 31, 2015 | 05:29 PM
TXsilverado's Avatar
371.xx
Old Jul 31, 2015 | 05:55 PM
371.xx
Thanks brother. Knew it was somewhere around that.
Old Jul 31, 2015 | 06:00 PM
BigKID's Avatar
371ci or 6.1L. If you go that route be sure to have your machinist do a sonic check on the block prior to boring it out. My machinist said he has seen several 6.0L iron blocks be too thin at the water jacket to take it out that far. Luckily mine was thick enough. I would not go .040 out unless you are trying to fix a problem. Lots of off the shelf pistons for 4.030. 4.040 is going to require a custom slug.
Old Jul 31, 2015 | 06:21 PM
That's what it took to clean the bore up. He checked the block before doing it.
Old Jul 31, 2015 | 06:40 PM
Vortec350ss's Avatar
At that point its likely cheaper to get a different block and shelf pistons... i could be wrong though.
371.44 CI
371.44 CI
That's exactly what I came up with.
