Fist pass out on the new set up went 9's, 3 consecutive 9 second passes at that. This is a daily driven full weight legit street truck. Weighs about 4500-4600 lbs with me in it. Still has air conditioning and touch screen apple car play radio lol. LQ4 block and crank, gen 4 rods and pistons. Ported 799 heads, BTR .660" springs, LSXceleration 226/230 .625"/.625" 114+4 cam, TBSS intake/LS3 TB, VS Racing 80/96, Huron Speed T6 kit, dual Magnafuel 4303 pumps, Bosch 210 injectors, Holley Terminator x max ecu, Mickey Thompson ET street radial pro's, 315/60r15. Stock 4L80E with a TransGo HD2 kit, Circle D 252mm converter with 4800 stall speed, 3.90 gears with a TrueTrac diff.
Thank you. Yes on e85 (more like e70 but I have a flex sensor). I launched on 8psi, saw 19psi for about half of the track then trickled up to 22psi on the big end.
