Good 6.0L CAM
Old Jan 28, 2008 | 09:35 PM
ONLYA4.8L's Avatar
Default Good 6.0L CAM
Got a 6L and wonderin about a good cam to run so it cam run like a bat outta hell... I have a 3200stall.. its outta an 05 denali and going into and 01 scsb with 4:10s Right now I have a 226/226 .580/.580@112lsa.. Can I run anything that may bbe better for it?
Old Jan 28, 2008 | 09:54 PM
TouchOfEvil04's Avatar
with a 3200stall i'd roll that 226 cam you already have myself.
Old Jan 28, 2008 | 10:12 PM
onebadrubi's Avatar
If it is a loose stall I would look into a high compression motor, 10.3+, and you should have good results with something like 226/228 or 226/230.
If its 3200 behind that 4.8l it is going to be a high 3k stall behind a 6.0.
Old Jan 29, 2008 | 07:56 AM
ONLYA4.8L's Avatar
cool.. thanks.. It s actually an 06 6.0L... Ill use that 226.. I was askin cause I have N2O also and dont wanna up the compression too much..
Old Jan 29, 2008 | 09:18 AM
ap2002's Avatar
Im running that 226cam on mine, I am an ext cab, so you should see some very nice times out of it for sure... i am also spraying on that cam, with stock heads, look at my sig...
Old Jan 29, 2008 | 10:18 AM
99Silverado5.3's Avatar
+1 should roll out in a single cab.
Old Jan 29, 2008 | 06:21 PM
ZR1 DREAMING's Avatar
I plan on a near identical cam in my temporary 6L. It should have good street manners but still make decent power.
If it was a permanent motor for me, I'd up the converter to a 3600 and thow a larger (230/232 590 600 113 -ish) cam in there though. JMO
Old Jan 29, 2008 | 07:10 PM
Silver-Dollar's Avatar
I am running the TSP 224r on a 112. I have considered going to a TSP Torquer 2 but I doubt I will.
Old Jan 29, 2008 | 07:50 PM
I'M runnin a similar cam from patriot,and it pulls great in the 6-speed truck
Old Jan 29, 2008 | 09:12 PM
ONLYA4.8L's Avatar
now got that covered.. Thinkin of usin my factory ecu but programmed for my new motor.. will it work?
