Bearing clearances
Looking for some help from the LS guys. Iron 4.8/5.3L gen IV block. Scatt crank, scatt rods. Engine will be FI from a turbo. What are guys setting main and rod clearance to. I have been getting much mixed info on this so I am curious on what other people have been using.
Scatt said LS rule of thumb .001 clearance for every 1 journal diameter puts me at .00256 mains and .00209 rod clearance
Mahle the bearing I am using says .00075 to .001 per journal diameter so that leaves clearance at .00192-.00256 main and .00157-.00209 rods. Mahle also says to add .0005 to the standard clearance for high performance engines. Which could bump me up to .00242-.00306 main and .0162-.00259 rods
Machine shop I have been using said mains at .0025 and rods at .003 for clearance
(Seems weird as that would put the rods with .001 extra clearance and the mains right on spec.
Published books (how to build and modify GM LS- series engines by Joseph Potak) says stock to mild performance .0008-.00210 main, .0009-.0025 Rod and high performance to racing .99250-.00275 Main, .00225-.00250 Rod & (how to build build GM LS-series engines by Chris Werner) says .0025-.0030 mains .0021 rods.
Mangled03gmc
Aug 22, 2009 02:48 PM
