Electric fans or clutch
Old Nov 15, 2011 | 07:51 PM
kogelch's Avatar
Default Electric fans or clutch
I currently have a clutch fan thats on all the time because its locked up. I thought about replacing with electric fans. I hear electric fans can free up some horsepower but Is it worth the $500 -$600 for electric or should i stay with the clutch. Any suggestions.
Old Nov 15, 2011 | 07:56 PM
Jrluz14's Avatar
You don't have to buy $600 electric fans. There's actually a set on here now for $100. Then a harness from blackbear is another $100, but you can often find those here in the classifieds as well. Then a tune and you're all set.
Old Nov 15, 2011 | 08:05 PM
Slammed96's Avatar
Electric fans. You can usually find a good set pretty cheap, and like Jrluz14 said, you can also get a harness pretty cheap to.
Old Nov 15, 2011 | 08:39 PM
TXSZ66AVLANCHE's Avatar
On my 03 Burb & 04 Avalanche the e-fan mod is one of my favorite mods done, well worth it!
Old Nov 16, 2011 | 09:16 AM
CalEditor@PCMCalibrators's Avatar
FormerVendor
The 2003 + GMT-800 trucks have the ability to have the electro-viscous (EV) fan clutch installed
Old Nov 16, 2011 | 08:47 PM
kogelch's Avatar
Thanks for the advice.
Old Nov 16, 2011 | 09:16 PM
kogelch's Avatar
Are you able to provide any links or web addresses where i can find the fans and the harness. Does this site have a used parts area.
Old Nov 16, 2011 | 09:51 PM
dmelvin's Avatar
If you do the swap to electric fans you'll have to get your PCM programmed to run them.
Trick Performance products has a electric fan kit that has the fans and the shroud for like $185, and you can pick up a E-fan harness from Nelson or Blackbear for about $100
Wolftrk99
Dec 3, 2015 08:12 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
