B5908 - Fuel Mixture Spark Correction table question
Old Dec 17, 2007 | 05:45 PM
BlackGMC's Avatar
Resident Retard
Default B5908 - Fuel Mixture Spark Correction table question
I have a question about this table. Does this table operate all the time or just in PE?
The row values on this table are in GMEq. Do they translate like the following? Attached is my stock 4.8 table, I added the AFR column.
If so, does it mean given a certain AFR and RPM this is how much the PCM will add/substract Timing?
Does a Negative add timing and a Postive substract?
Old Dec 17, 2007 | 06:47 PM
Rhino79's Avatar
9 Second Club
All the time I do believe, but I think you have your AFR values figured on Lambda instead of EQ. Should be the other way around, above 1.0 is richer and below 1.0 is leaner. As far as timing, positive values add to the final value and negative ones subtract from the final value.
Old Dec 17, 2007 | 06:57 PM
BlackGMC's Avatar
Resident Retard
thanks for the answers so does this look better?
Old Dec 17, 2007 | 07:26 PM
Rhino79's Avatar
9 Second Club
Yep, that looks right now.
Old Dec 17, 2007 | 08:52 PM
dc_justin's Avatar
Hello Dave
I concur with everything Rhino said.
Old Dec 19, 2007 | 10:03 PM
Dirty Dave's Avatar
Less than 1.0 is richer higher than 1.0 is leaner. In other words .8 rich 1.2 lean.
Old Dec 19, 2007 | 10:05 PM
Rhino79's Avatar
9 Second Club
In Lambda terms yes, but EQ ratio is opposite.
Old Dec 19, 2007 | 10:18 PM
Dirty Dave's Avatar
Didn't notice the eq.
USMCvet0311
Aug 1, 2015 07:45 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
bsn1989
Jul 16, 2015 08:20 AM
Suburban2500
Jul 14, 2015 02:10 AM
jrplz
Jul 9, 2015 12:07 AM
