combination?? help
Old Feb 6, 2024 | 05:26 PM
learning101's Avatar
Registered User
Default combination?? help
ok i have read a lot of different thoughts on this but got a boat 2002 Avalanche 5.3 Vortec 4x4 706 heads dish pistons. i have a set of 799 heads milled 30 thousands. swapping the 706 for the 799 better flow so im adding flat top pistons { what sorta of compression you think I'm at? } stock truck cam . Question would i need valve relief spots in the pistons with a truck cam stock?
Old May 21, 2026 | 01:47 PM
RB04Av's Avatar
5 Year Member
As to the original question, that would be a No. The 4.8 used flat-top pistons, 706 heads, and the same cam as the 5.3, and didn't need VRs. The LQ9 used flat-top pistons, heads that located the valves at the same height as the 706 heads, and bigger cam; and didn't need em. You'll be fine.
Your CR will probably be somewhere slightly higher than the L33, which was right around 10.0. So, call it 10.3 as a starting point, more or less.
Old May 24, 2026 | 02:32 PM
RB04Av's Avatar
5 Year Member
clean up Isle 3
miguelc
Aug 6, 2012 05:57 PM
LS1TRUCKGUY
Jul 2, 2012 11:46 AM
2doorfury
Apr 29, 2012 03:22 PM
05gmcsierra
Mar 31, 2011 02:41 AM
99/5.3w/hips
Aug 24, 2006 03:53 PM
