TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Body Lift Questions
Old Aug 27, 2012 | 07:43 PM
MiniLSx's Avatar
Default Body Lift Questions
Hey guys, I was considering doing a body lift. Can anyone with experience with them give me some pros/cons? Also I was wondering a few things:
Do most kits come with a steering linkage extension?
I have a manual shifter for my 4wd, will my **** be super low or anything or will it not effect it?
Will my coolant hoses be stretched too much, or do I have to modify them in any way?
Whats the best kit out there for body lifts?
Thanks in advance.
Old Aug 27, 2012 | 08:08 PM
2000chevysilverado's Avatar
Body lifts are a pain to put in done 2 by myself easier with help. Your hoses will be fine and yes on steering linkage floor shifter you will have to make a extension or no 4lo. Imo don't get on get a set of blocks and keys much easier and if you have a wreck with a body lift kiss you truck goodbye
Old Aug 27, 2012 | 08:39 PM
MiniLSx's Avatar
Well i've got a RC 2" leveling kit in the front right now
Old Aug 27, 2012 | 09:02 PM
ChevyTruck's Avatar
something else
Con, the hitch and exhaust will be 3inches lower if you raise the bumper up. The front bumper will be a pain in the *** to get on straight. 3" of the frame will be showing.
If you do it make sure you buy a tube of Red Thread lock and use it. I had a few bolts that came loose when I had the body lift on my 2K2.
Old Sep 5, 2012 | 10:52 AM
Platinum WS6's Avatar
I put a 3" Performance Accessories on mine. It did take a 3 day weekend to do it by myself but its possible. The bumpers are a pain but take your time and it will look good. All linkages and brackets come with the kit as well. Hitch does hang lower and I had a new exhaust ran so thats no biggie. If you only want something like 33's just ket the keys and be done with it but with the 35's I have I do recommend the body lift. Good luck...just remember its a lot of work but not hard work.
Old Sep 5, 2012 | 12:22 PM
rj2's Avatar
rj2
Pros looks and bigger tires. Cons no performance gains as far as suspension travel to off road. The exaust hitch and rear bumpers although its a pain can be moved to look like factory. Youll see daylight in rear fender wells between bed and fram unless u get gap gaurds. Honestly you should look like into a 4good inch suspension lift. There really not hard to do and come with everything you need. Ive seen them on craigslist very reasonable and i wouldnt be afraid of a used lift. You can look at the bushings and all to make sure there ok. And its safer and gives your truck more off road capability than a body lift. Looks better imo too. Theres nothing wrong with them but there a headache. Id look at suspension.
Old Sep 5, 2012 | 09:36 PM
rj2's Avatar
rj2
You could just get a kit for the front end and block the rear. I dont know if someone said that or not. You could replace the torsion keys and get another 3 inches in the front then just get 3a inch bigger blocks in the rear. You wouldnt have to adjust or move or do anything really to steering bumpers 4x4 etc. I think (not 100%) that f-150 keys will give you 3 inches in front
Old Sep 16, 2012 | 11:39 AM
boosted_blue's Avatar
IMO bodylifts look exactly like they cost. CHEAP! Save up and go full suspension lift and you will be happier in the end.
Stainless Works
Nov 20, 2015 08:55 AM
thunder550
Oct 8, 2015 04:53 PM
brandon6.0
Aug 7, 2015 11:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
08nali
Jul 23, 2015 11:39 PM
