Project 50 Shades LSXAP Shoptruck
Old Dec 29, 2015 | 10:42 PM
  #241
lsxperformance's Avatar
Originally Posted by GMCtrk
that turbo looks ******* badass.
I want.
Thanks man! Ya me too been waiting for it since February 2015. As well as the hotside. Wish I knew it was gonna take sooo long I woulda went a different path, and probly made my own.
Old Dec 29, 2015 | 10:47 PM
  #242
Originally Posted by Blown06
Have you already sent the heads to Frankenstein?
Not yet no aquireing parts for a 4.8 setup this next year while I'm building the 427. So it Dosent sit too long. I may put the turbo on it for kicks I haven't decided yet. I have spray too so It would probly spool decent ha. If it does go on it I probly won't push it very hard till the 427 is done.
Old Jan 10, 2016 | 11:12 AM
  #243
Here is a pic of the down pipe.. It starts at 5" then uses a ljms 5-4" reducer so I can keep ac. Because street truck..
Hotside was mocked up and fabbed at Sinster Racecraft in Port Isabel, Tx. I will be doing the cold side.
Old Jan 10, 2016 | 02:59 PM
  #244
Vortec350ss's Avatar
It's coming along!
Old Jan 10, 2016 | 04:11 PM
  #245
BlackGMC's Avatar
Resident Retard
Looks good man
Old Jan 19, 2016 | 08:25 PM
  #246
Thanks guys! I sold the LSA blower setup. The turbo and Hotside, down pipe, and the dual Turbonetics gates showed up.
Most guys compare the turbo to pop cans.. I compare mine to 5gallon buckets!!
Old Jan 19, 2016 | 09:16 PM
  #247
I acquired a 05 4.8 for 250$ W/325k miles from a local salvage yard. Upon tearing it down for inspection, I learned some things.. It is a gen III engine, but the deck has short head bolts and the rods apear to be full floating I was kinda suprised to see that normally on a lot of the 6.0's I've gotten had the longer head bolts and pressed pins. Other than the Denali and escalades atleast for the iron blocks. Maybe that's just my luck. Ha, just thought was abnormal luck for once. I prefer the short head bolt motors when l lean hard on them. Anyhow I'm going to check it all out run a ball hone thru it, probly throw a set of rings in it, file them loose, and run it this season. While I build the 427 setup.
I hope I don't regret this, the lifter guides had mold growing in the sludge build up, the rocker arms were rusted and one of the cylinders had some minor pitting from something going thru it like a plug or dirt or something.. Anyhow I hope I don't regret this. I will probly play it safe for a bit on it. Under 20psi till the 427 is built then I'm gonna see how far it can go.
Old Jan 19, 2016 | 09:23 PM
  #248
1FastBrick's Avatar
Custm2500's Rude Friend
So you got the small turbo then...
All the 05 up Gen 3 LS motors are like that. Short head bolts and floating pin rods.
Old Jan 19, 2016 | 09:54 PM
  #249
I know they were all supposed to have, but had yet to have seen it happen lol
Old Feb 17, 2016 | 10:57 PM
  #250
Just an update:
I sold all the LSA Supercharger parts, the 8 rib accessory drive and the blower cam, and the 10% over drive pulley. The 4.8 is nearing completion I got notification the cam shipped today. So I mocked the Turbo stuff up on the 4.8 on the stand and saw the flanges on the log were warped really bad. Not terribly happy about it, dunno what's gonna happen I'll probly just build my own I'm tired of relying on others to do things. I'm very picky, it's another set back of many.
