Lets Try This Again: 410-PT88-80e
Old Jan 8, 2011 | 08:14 PM
  #291
Atomic's Avatar
I have a gauge for that
You guys are right, I'm sick of having issues. If its a problem with the engine then I'm hoping LME fixes it and it'll be up for sale when I get it back. It sucks putting this much work into.something only to have it last a short time. The stock engine and blower setup seemed the most reliable with the least trouble.
But I'm hoping if I adjust the crankcase breather system and use an oil resistor I can solve my issues. Truth be told I liked driving the high compression blower setup more than the turbo.
Old Jan 8, 2011 | 08:37 PM
  #292
JoeyGC5's Avatar
Bryan give you an limits on boost for the motor?
Old Jan 8, 2011 | 08:47 PM
  #293
Atomic's Avatar
Nope, said it would be good to 900hp though
Old Jan 8, 2011 | 09:40 PM
  #294
Bumpers's Avatar
I hope nothing is wrong with the engine.. If so time to go to a stock 6.0 and a 76mm
Old Jan 9, 2011 | 12:04 AM
  #295
iamkeniff's Avatar
i really hope this is the last set back.
if so im serious about the mentioned combo... no need to drop the turbo size, that SCSB had a 88 on a stock 6.0 and was running 15-18psi for many MANY passes.
Old Jan 9, 2011 | 12:21 AM
  #296
1989k1500's Avatar
That sucks man.
If something happened to the engine I would just sell it and put your 5.3 back in and put a smaller turbo on it and rock out.
  #297
Daryn's Avatar
Formerly darynC-10/23/10
did you run a oil restrictor in the turbo? if so .. what size?
Old Jan 9, 2011 | 12:52 AM
  #298
Atomic's Avatar
No oil restrictor, I wasnt under the impression I really needed one until now.
Old Jan 9, 2011 | 01:01 AM
  #299
Daryn's Avatar
no oil restrictor will put way to much pressure on the seals
if your running a -4 or larger oil feed. you should put between a .065-.070..nitrous jet!
i have a .065 on mine.
Old Jan 9, 2011 | 01:04 AM
  #300
Atomic's Avatar
If the compression test comes out fine then I will be putting in a restrictor and I guess getting rid of the catch can and just using a breather on the driver side. The oil feed is -4.
