Lets Try This Again: 410-PT88-80e
#291
You guys are right, I'm sick of having issues. If its a problem with the engine then I'm hoping LME fixes it and it'll be up for sale when I get it back. It sucks putting this much work into.something only to have it last a short time. The stock engine and blower setup seemed the most reliable with the least trouble.
But I'm hoping if I adjust the crankcase breather system and use an oil resistor I can solve my issues. Truth be told I liked driving the high compression blower setup more than the turbo.
#295
i really hope this is the last set back.if so im serious about the mentioned combo... no need to drop the turbo size, that SCSB had a 88 on a stock 6.0 and was running 15-18psi for many MANY passes.
#300
If the compression test comes out fine then I will be putting in a restrictor and I guess getting rid of the catch can and just using a breather on the driver side. The oil feed is -4.
