Lets Try This Again: 410-PT88-80e
Old Jan 9, 2011 | 05:49 PM
  #311
Atomic's Avatar
I have a gauge for that
Spark plugs look terrible, especially the back ones
The back ones look lean, and show signs of detonation. The most timing I ran was 14 degrees and my IAT spark table is pretty aggressively pulling timing. My fuel setup has -8an lines to the front of each rail, then -6 lines from the back of both to the regulator....do I need some sort of crossover between the rails on the back end before the regulator? Highest injector duty cycle ive seen is around 90. This is with 60lb injectors and base pressure of 50psi with a boost reference.
I cant get my compression tester to thread into cylinder #8 (the one im most worried about, go figure), so I need to get a thread chaser tomorrow...
Results from the compression test, keep in mine it was 30 degrees outside when I was doing this
8-? 7-140
6-170 5-130
4-150 3-155
2-150 1-180
Old Jan 9, 2011 | 05:54 PM
  #312
sprayedenali's Avatar
damn the luck!!
hopefully you get all this sorted out!
Old Jan 9, 2011 | 06:23 PM
  #313
schino's Avatar
man this whole thing sucks. was thinking at first you pushed past the seals on the exh side of the turbo so you just dumped oil out the exhaust and never went through the motor but those plugs dont look good. 5,7,8 dont look pretty
Old Jan 9, 2011 | 07:47 PM
  #314
MikeGyver's Avatar
Did you ever fool around with your knock sensor sensitivity? I can barely run 10 psi and 14° timing without KR.
Old Jan 9, 2011 | 07:55 PM
  #315
Atomic's Avatar
I was getting some KR off-idle and low rpm and low load, but didnt really get a chance to figure it out yet. I messed around with the sensitivity a few years ago when I first started tuning, never had an issue until now.
Just checked, the base attack rate is 65% of the factory settings with that being the only change.
Old Jan 10, 2011 | 01:47 AM
  #316
Spoolin's Avatar
GFYS and STFU
I think that 20psi+ action might of done more harm than laughter. I think the tune did you in, hopefully it's the turbo seal though...
Best of luck!
Old Jan 10, 2011 | 02:44 AM
  #317
Daryn's Avatar
Formerly darynC-10/23/10
yikes man no liking the compression in the 5 and 7
Old Jan 10, 2011 | 02:47 AM
  #318
AKlowriderZ71's Avatar
11 Second Hall Moniter
Need to add leakdown test to your "to do" list.
Old Jan 10, 2011 | 07:33 AM
  #319
CurtD's Avatar
10 Second Truck Club
Best of luck!
Sux but I'm with spooler..
Old Jan 10, 2011 | 10:22 AM
  #320
Atomic's Avatar
I drove it around fine after that for more than a day and didnt see any symptoms or damage, it was at 20lbs for no more than 3 seconds until I got out of it.
