ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Feb 9, 2018 | 03:56 PM
  #61
BudRacing's Avatar
I'd guess those inner marks on the axle housings are from a bolt on rear sway bar.
Old Feb 9, 2018 | 05:25 PM
  #62
ILuvJDM's Avatar
I realized it was from the oem saddles, they make three marks, so nothing out of the ordinary in that regard
Old Feb 10, 2018 | 02:00 PM
  #63
ILuvJDM's Avatar
I couldn't get the AEM wideband plug through the firewall, so I depinned it and got it through and routed across the engine
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-yeoyhus.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-4xzogu4.jpg
Success
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-tk3zw5a.jpg
Routed and zip-tied
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qgctjta.jpg
I used a diode bent in half to depress the two pins required at the same time
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-vi9bwxa.jpg
Here we go again
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-fcjrh18.jpg
You can tell previous owner had axle clamp on it for axle wrap, it bent the springs
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lhfjr5q.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gvbhjba.jpg
Made all the modifications needed for the traction bars
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ftp0hpi.jpg
Pressure washed and added some rust remover to the surface rust areas
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-tjxscbf.jpg
Inside of the shackle bushing hole was very rusty, so trying to get the scale off
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-57jtbvt.jpg
New u-bolts and poly bushings came in the mail
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hdkqvax.jpg
Lots of excess threads, but they should have enough threads to apply pressure with the flip kit, which was my worry
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-enuwh5r.jpg
Old Feb 10, 2018 | 05:33 PM
  #64
ILuvJDM's Avatar
Got the poly bushings installed as well as the front brackets for the traction bar. Got them put on the truck and called it quits for the day. Tomorrow I'll lower the axle down and install the flip kit hardware and u-bolts
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-h1zthti.jpg
Old Feb 15, 2018 | 06:57 AM
  #65
ILuvJDM's Avatar
Back on all 4 tires
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-0huz2w6.jpg
Axle seems to be over to the passenger side a bit more than the drivers
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-3a1t2e7.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qm2b4py.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-joqj0gm.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-t3r3yxt.jpg
Center of notch marked
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-csnzi77.jpg
Old Feb 15, 2018 | 08:15 AM
  #66
AlljackedupZ71's Avatar
What brand traction bars are those?
Old Feb 15, 2018 | 09:21 AM
  #67
ILuvJDM's Avatar
VAS low profile version for flip kits
Old Feb 15, 2018 | 12:01 PM
  #68
black04's Avatar
Do the 2014+ wheels still tuck like the nnbs wheels? Looks like they stick out more.
Old Feb 15, 2018 | 01:31 PM
  #69
ILuvJDM's Avatar
pretty sure they are the same, the rear passenger side looks more flush because the axle isn't centered on these trucks from the factory. I looked into the axle centering thing and found a ton of threads on multiple forums about it, and the general consensus is every truck has the same issue with axle being pushed to the passenger side
Old Feb 15, 2018 | 01:36 PM
  #70
Atomic's Avatar
I have a gauge for that
You want it slightly offset so the ujoint cap velocity is not zero, but its generally <1degree. If its dead on perfectly aligned the cap doesnt rotate and doesnt get lubricated properly.
