ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Jan 13, 2018 | 11:49 AM
ILuvJDM's Avatar
Default ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
So I got tired of the gray truck and my priorities and tastes changed since I bought the gray truck. I wanted something I could daily and still be practical for work, but the truck was just too beat up to even get excited about.
I searched for a few months for a low mileage V8 RCSB with power accessories, and finally found one in Indiana. I spoke to the guy for a few minutes and bought it sight unseen and had it shipped to Texas. Paid $13,900 for it, or $14,500 total with shipping.
Details: 2007 classic with 44k miles, 5.3L, 2wd, power windows and locks, dark charcoal interior, flex fuel. It was owned by an older guy in his 70s who seemed to take very good care of it.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-is4v9xk.jpg
Grandpa status with the wheels and bedcover
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-e9zu5cb.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ocn9otu.jpg
Took that off the next day
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-jeg563r.jpg
Overall, pretty clean
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-bzgwx6s.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-vpzqohz.jpg
Antenna delete and escalade panel cover
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-abtvpch.jpg
Added my DL3 mirrors and took caps off to paint red
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ny5jz3o.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-b6sjaij.jpg
Door speaker grills had surface rust
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ebmacam.jpg
Painted with my Graystone Metallic which is a good match
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dzysxo4.jpg
A lot of the parts were taken from my gray truck, since they were new OEM parts like this battery tray
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-uoyz3zt.jpg
Swapped my XS D3400 battery and some wiring
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-bj8xepo.jpg
Roof was scratched by the tarp in shipping, but should buff out
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-uul74jj.jpg
Fleece module, much nicer than diodes
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qcoy80k.jpg
Bought an escalade center console for a project
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-pczqypk.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-48optxr.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-b3z53ju.jpg
The carpet came off super easy on this side, but not the other
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-wycitob.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-w9fwysx.jpg
ILuvJDM's Avatar
Debadged the LT emblem
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gioxrg6.jpg
And the tailgate
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-xjnym1v.jpg
Originally thought the bushings were bad, so I ordered the daystar poly ones, but this was actually just a rubber washer that was damaged. Either way, swapped the daystar bushings in because the rack was out anyway
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-u9by3y4.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hispzsv.jpg
Tore the interior apart to install a steering wheel with radio controls, new clockspring, my remote start and alarm, etc..
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-g2kftfb.jpg
Added a cabin filter and door
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-vkfvih9.jpg
Then I had to take it to get it inspected and registered, and decided to tear into the suspension at this mileage
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-u2qvfrs.jpg
Put it on jackstands that weekend and it hasn't been off them since
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dg0ccqy.jpg
Started the tear-down and measuring for coilovers
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-8twcurp.jpg
Found some rust in a few nooks, but not bad at all for a truck from up north. The frame coating is still perfect on almost the entire truck
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-x9saatx.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-higfcx9.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-2kbd6ie.jpg
At this point, I figured it would be very easy to install the turbo with all that room I made, so the tear-down began
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-jxdvrqr.jpg
Couldn't get the drivers manifold off because of one nut that was stripping, so I tried to get it out in one piece connected to the y-pipe. Didn't work
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-m1qiqal.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lay8idb.jpg
Busted out the sawzall
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-jjstbcm.jpg
Hammered this socket on and it came right off
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lphmeho.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-3qmmlxj.jpg
Since I had 706 heads, I decided to check for the casting mark and they are indeed the Castechs that are prone to cracking
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-in5ngbo.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-agrnmbe.jpg
Old Jan 13, 2018 | 11:50 AM
ILuvJDM's Avatar
Started test fitting the hot pipes
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ctbbdn0.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qm745bi.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-txod04f.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-bgnqcti.jpg
Then did some cleaning
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-klqzwmn.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-fu0n8hm.jpg
Started mounting my trucool 40k, I later trimmed the top bracket down so it's not blocking airflow
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-532w5lt.jpg
Trimmed the power steering cooler mount because I hate when these are mounted off-center
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ppnsqjs.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-d0tdbih.jpg
At this point I decided to do heads, cam, lifters, ARP studs, etc... and started the teardown even further
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ltokltz.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-oqecgtm.jpg
Forgot to take pictures, but I prepped and painted the front edges of the block with satin black engine paint and cleaned all the aluminum up
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-3eoiygn.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-xw0f8ef.jpg
Measuring to figure out what kind of injectors I have. They're not typical truck injectors since they're flex fuel and '07 year
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-p810eoo.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-naijiws.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ygc7u6i.jpg
At this point I decided to get more realistic with the project and try not to do too much at one time, so I decided not to do the headswap, cam, etc... but instead went with trunnion upgrade and PAC 1218 springs and start getting everything put back together
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-xv5m6q3.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-5rqf2lz.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-damnfxs.jpg
Sealed up the knock sensors with red RTV
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-fnemhdh.jpg
ILuvJDM's Avatar
Degreased and pressure washed the intake manifold. You would not believe how much oil and **** came out of this with the stock PCV setup
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-x3tkgzp.jpg
All new intake manifold, valve cover, and throttle body gaskets since they were in my garage already from my gray truck high mileage project plans
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-3orgoam.jpg
Nice and clean
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gyrv73g.jpg
Test fit the intercooler and made it as high as I could
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lwhhiej.jpg
Got the hot pipes back from ceramic coating
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-p0cuwiv.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-2ys8m5f.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-imqoyzl.jpg
De-loomed the MAF wires from the harness and brought them over to the back of the engine
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-fjrht8c.jpg
These little details are what I pride myself on, I took care to be able to re-use the factory firewall clamps so it looks OEM when it's all done
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-t9nehly.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-0h8bu9p.jpg
Wrapped in techflex
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dlijqgu.jpg
Added a breather filter to the passenger valve cover
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-vaqgmpw.jpg
Drilled and tapped the compressor cover for great boost response from the wastegate
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-jspkhll.jpg
Test-fitting three piece covers, the passenger side will need to be cut to work with the turbo, unfortunately
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qel4hke.jpg
Oil pan drilled, tapped, cleaned and new gasket installed
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-05mj5sm.jpg
Then I put the necessary parts on to be able to start it up and check for leaks
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-xbovtfn.jpg
Started it up and let the turbo drain oil and clear out any possible contaminants
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-u8co7aq.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-wcqxidm.jpg
Also temporarily installed my LCA's to measure for coilovers
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lsxygxf.jpg
Going for 15.0" hub to fender ride height which will be around 4.5" drop from stock
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-71witki.jpg
Old Jan 13, 2018 | 11:51 AM
ILuvJDM's Avatar
Dropped something on my drill and destroyed the battery, that was annoying. Great way to start the garage session
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-zriyigm.jpg
Worked on finalizing the plumbing for cooling system, and added a drain petcock to the lower hose. Draining these systems is an absolute mess since you just have to pull the lower hose off and let it fly. This should help with that.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-mgujtd2.jpg
I take my time with routing of lines to make sure it all looks good, but also functions well and doesn't get in the way of other items
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-izjxakx.jpg
Added DEI flame proof sheathing to the oil drain line
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-jl9ijzv.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-zanw7dr.jpg
Finished my heater lines. Took the mount off the valve cover and added that to the coolant tank leg for a super clean install. Also keeps the lines in place
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rwkw07f.jpg
90 degree Gates hoses
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-irrgrmy.jpg
With a splice for the line that is connected to the main coolant hose factory setup. Also wrapped the lines in techflex for rub protection. There is more DEI sheathing on these lines as they run by the wastegate area
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rjgnoc7.jpg
And that is where I'm at as of 1/13/18, more to come as the build continues. I will keep this updated now that I found a new image hosting site since photobucket **** the bed.
Old Jan 13, 2018 | 03:06 PM
GMCtrk's Avatar
Incredible attention to detail
I would re-do the oil drain line though. With it rubbing on that nut it may eventually burst leading to catastrophic failure.
Old Jan 13, 2018 | 06:15 PM
ILuvJDM's Avatar
Thank you.
I think the picture is a bit deceiving, it also makes it look like it's flat, when it actually heads downhill the whole way. I will check it again tomorrow, but I believe the only thing touching is the fire sleeve because of how large it is. Worst case scenario I will find a way to secure it over and gain clearance. Thanks for the heads up.
Decided to tackle the POR15 job today, what a pain. I just slopped some on in the areas I couldn't access and hope it works
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hw4hney.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-luqsyne.jpg
Also cleaned the inner fenders, even though it'll never been seen once the plastic liners go back in
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-71nvmqk.jpg
Permanent install of the lower control arms from VAS. Also ran to tractor supply and grabbed some grade 8 hardware for the coilovers which I ordered today from Atomic
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rzc6xfg.jpg
Old Jan 13, 2018 | 08:26 PM
D1SCSS's Avatar
That is a badass truck!!! Keep up the great work!!!!
Old Jan 13, 2018 | 08:46 PM
Feed's Avatar
Very nice
Old Jan 13, 2018 | 10:44 PM
Shaggy2dope's Avatar
I like your style. Clean!
