ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old May 10, 2019 | 05:18 PM
  #441
ILuvJDM's Avatar
Sub box, subs, and amps were 87lbs, so I would guess just under 100lbs with wiring, fuses, screws, etc...
Old May 26, 2019 | 07:32 AM
  #442
ILuvJDM's Avatar
Cleaned and painted the oem calipers and purchased a z36 powrstop kit. Going to remove the wilwoods in the future so I can run a drag pack front and rear
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hgo900a.jpg
Wired in my MPVI 2 pro interface to the wideband and started the new tuning process with Atomic.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-zu5cdqd.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ifcam78.jpg
First file he sent me it idles and drives like a stock truck. Previous shop had the truck for over a month and tried to blame it on the parts I used on the build, or injectors too big, or the PCM, etc.. The truck would stall going from park to drive or coming up to stop signs, and all sorts of issues. I definitely wish I had never gone to that shop to begin with, but live and learn.
Old May 26, 2019 | 07:44 AM
  #443
Dangles's Avatar
Great call going with Richard. He’s responsive, knowledgeable and a great tuner. I just finished up tuning with him and it was an awesome experience. Can’t wait to see this thing tuned and on a drag set up
Old May 26, 2019 | 01:27 PM
  #444
terravast4's Avatar
glad to hear you got it sorted out. You tuning for more boost right now?
Old May 26, 2019 | 02:53 PM
  #445
ILuvJDM's Avatar
Not right now, just getting it dialed in on 93 octane and 10psi. I will eventually make the switch to E85 and install my boost controller, but priority here is to get the truck running great so I can actually enjoy it. Driving it lately has been very annoying and actually added more stress to my life, when driving this truck is supposed to be a stress reliever in theory...
Old May 31, 2019 | 05:57 PM
  #446
ILuvJDM's Avatar
Wilwoods are off the truck, going to have to edit the thread title now...
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ondweu3.jpg
Powerstop Z36 kit with the OEM calipers I painted black. Got new slide pins, seals, speed bleeders and russell stainless lines
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-oreqhox.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-fl1gy3f.jpg
Old Jun 1, 2019 | 01:03 PM
  #447
terravast4's Avatar
I am curious how different the feel is from the wilwoods
Old Jun 6, 2019 | 09:17 AM
  #448
atxjustice6r's Avatar
You know I'm "with" this swap, John. But damn is that a lowly sway back to stocks haha. Gonna be worth it in the end
Old Jun 27, 2019 | 05:50 PM
  #449
ILuvJDM's Avatar
Oh what a fun afternoon. Went to change the MAP sensor and I tried to take a shortcut and long story short the gasket fell into the intake manifold. Left me no option but to remove the fuel rails, intake manifold, etc...
Found it sitting on top of the valve in number 7
I felt like a brain surgeon getting it out with the borescope and needle nose pliers...
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qxywryf.jpg
Took a few hours but it's all back together now. Won't make that mistake again.
Old Jun 29, 2019 | 12:29 PM
  #450
ILuvJDM's Avatar
I'm trying to solve a 60mph shake in the rear end, so looking at pinion angle first. These are the measurements from the tremec app:
Angle 1 was tranny/driveshaft and angle 2 was driveshaft/pinion yoke.
I have a 2° shim in my garage right now. I need to install the fat end at the back so it pushes the pinion down and gets that angle closer to the tranny/driveshaft angle, correct?
