ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Sep 1, 2018 | 02:02 PM
  #341
SDjeff619's Avatar
What’s the max load of those tires? My g2’s 295/40/20 are 2337 lbs. I’m kinda questioning the load on the fronts and pushing it in the corners. The side wall is definitely a little soft for the weight of the front of the truck.
Old Sep 1, 2018 | 03:00 PM
  #342
ILuvJDM's Avatar
2094lbs according to Nitto
Nitto doesn't make a 275/45/20 nt555, but here are some other specs:
Nitto 421Q - 275/45/20 - 2337lbs
Nitto 421Q - 275/40/20 - 2094lbs
based on that, you can assume that basically they were telling me you can't run 275/40/20 on a RCSB, which we all know is bullshit
Old Sep 1, 2018 | 05:48 PM
  #343
408gto's Avatar
A friend of mine has a 03 1500hd lowered on 22” billet specialist running 305/40/22 since 2005 and its supercharged 6.0 drives the hell out of it with no problems he also works at Michelin and says that the tire ratings are underrated for this reason I also had 305/40/22 put on the wife’s heavy Escalade so it’s like a milk date just for reference
Old Sep 1, 2018 | 06:33 PM
  #344
408gto's Avatar
This is his truck
Old Sep 1, 2018 | 11:42 PM
  #345
01FormulaTA's Avatar
Discount gave me the exact same issues when I went to get my tires mounted on my CCWs, I even told them they were goin on RCSB (drove up there in my Avalanche) and they wouldn’t even mount them on the rims....had to go to a mom and pop tire shop to get them mounted
Old Sep 4, 2018 | 10:22 AM
  #346
JoshC.'s Avatar
I run 275/40/20 on my ext cab and discount mounts my tires no problem. What's the load rating on them 106?
Go in there and tell them 03 ext cab with the 235/75/16 option that was a factory load rating of 106. There system doesn't allow them to go below the factory load rating.
Old Sep 4, 2018 | 10:37 AM
  #347
ILuvJDM's Avatar
I don't know the load range of them, where would that be found? I told them it was a 2wd truck, I think those come with 245/70/17 stock
Old Sep 4, 2018 | 12:29 PM
  #348
JoshC.'s Avatar
It's a 106xl. There reason I say that specific one is same thing happened to me at discount, 03 had two option as far as tire either a 235/75/16 or a 255/70/16. The main difference the load rating the 255 has a 110 load rating same as a 245/70/17. That's why they wont do it. Just try another one saying it's a 03 or 04 shouldn't be an issue.
Old Sep 4, 2018 | 12:30 PM
  #349
terravast4's Avatar
the load rating is the last number on your tire size 275 45/R20 110....110 would be the load rating
Old Sep 4, 2018 | 01:04 PM
  #350
ILuvJDM's Avatar
Yeah these say 106W XL
So I should say 2003 Silverado with the 235/75/16 tires?
