I hope I'm not late for work!
Old Jun 10, 2013 | 01:08 AM
  #81
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by Atomic
Yea it was Bens thread that made me want to post mine at all...I havent been able to drive much because of rain, but what I have it feels fine. Would the aftermarket UCAs or just bolts be better?
If you want to do it just once, and be done, then do them both. You'll have the most adjustability possible. If you want to try one or the other, and maybe have to do it over again, then start with just the bolts because they're easier to do.
Another thing I do on really low 4x4's, is flip the UCA. But you have to press the ball joint out, and 180 it. Gives the upper ball joint a much better working angle.
Old Jun 12, 2013 | 12:04 AM
  #82
Atomic's Avatar
I have a gauge for that
I think I have all the issues worked out...its still fast
Have the soft spring in there and it makes 16-17psi with cutout closed and 20-21 with it open with controller set to zero.
Still having slight issues with the torque converter having excessive slip :/
Old Jun 12, 2013 | 03:48 AM
  #83
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by 53bowtie
Positive caster is not always a bad thing, it will make it much easier to turn when you have larger tires and such. It is much better to have postive than negative caster, though, as negative caster can cause wobbling in the steering wheel and will put more load on your PS pump. I would think for a drag only setup it should be fine. I ran 8-10 degrees postive caster on my Toyota 4x4 with large tires just to make it easier to turn and to take care of some wobble from tires that werent perfectly balanced.
When you want the truck to return to center while going very fast in a straight line, positive caster is a bad thing. If it drives alright that is what matters most but that caster is not good at all.
Old Jun 13, 2013 | 04:54 PM
  #84
Beatdown Z's Avatar
Laid Back
Did you check/calculate the percentage of convertor slip?
Or does it just feel like it slipping bad?
Old Jun 13, 2013 | 07:15 PM
  #85
Atomic's Avatar
I log input speed, output speed, and engine rpm and can see exacrly what the converter is doing
Old Jun 13, 2013 | 08:12 PM
  #86
TIM Z's Avatar
11 sec. Truck Mod
FMIC looks good man
Old Jun 13, 2013 | 11:22 PM
  #87
Atomic's Avatar
Went to the track today, ran a 6.52@107 with a 1.56 60ft and 15 degrees of timing and around 19-20psi. The temperature today was around a 105 heat index.
Turbo silverado work truck back at holiday beach - YouTube
I didnt realize I dont do **** with my right hand after I catch my laptop. I watched this video and went wtf, I dont remember just chilling
Old Jun 14, 2013 | 12:11 AM
  #88
Verz's Avatar
Sounds good, camera angle makes it look a little cramped in there haha
Old Jun 14, 2013 | 12:50 AM
  #89
Koots's Avatar
Probably the most casual 6.XX second 1/4 mile drag I've ever seen
Wearing shorts, holding a laptop, then just chilling up the track at 100MPH with one hand on the wheel like a true G
Old Jun 14, 2013 | 01:03 AM
  #90
kelsey_canard's Avatar
It aggrivates me how boring you make that pass look, damn 4wd guys Get me in an astro van and I'm pounding the floorboard with the gas pedal and ripping the steering wheel back........because race car
