I hope I'm not late for work!
Old Oct 20, 2014 | 03:15 PM
  #581
kbracing96's Avatar
Originally Posted by smokeshow
Gilbert does the billet intermediate before the billet input.
That's what he told me too. Said the weakest link is the forward hub cuz of the oil relief groves in the splines and the intermediate shaft cuz it's the smallest shaft in the trans. We didn't put any billet shafts in my tranny when he built it cuz I don't really plan on abusing it that hard, And he's in my back yard, so if it breaks, he said bring it back and we'll make it stronger!
Old Oct 20, 2014 | 03:45 PM
  #582
BlackGMC's Avatar
Resident Retard
Originally Posted by Atomic
Ill probably do it. Nothing personal against him or Blake, but I dont like relying on other people to do things for me when its within my capacity to do it.
Do it! if i can build one you definitely should be able to do it.
If you want i have 2 really good manuals for the 4L80 i can send you.
Old Oct 20, 2014 | 03:59 PM
  #583
Atomic's Avatar
I have a gauge for that
Well now ya tell me! I just bought the ATSG one off amazon. I assume that is one you have, whats the other?
Old Oct 20, 2014 | 04:04 PM
  #584
BlackGMC's Avatar
Resident Retard
It is one i found online. I used the combination of the two when i assembled mine. PM me your email address and i will send you both. I believe i have the electronic.
Old Oct 20, 2014 | 05:57 PM
  #585
GMCtrk's Avatar
Interesting, because according to Jake (Jake's transmission) the input shaft is the weakest shaft. Says the stock main shaft is good to 1200 hp versus 750 on the input shaft. The output shaft is nearly unbreakable.
Old Oct 20, 2014 | 06:07 PM
  #586
BlackGMC's Avatar
Resident Retard
When i built mine Vince B. helped me i think i remember him mentioning the input shaft upgrade was not needed in my case since i was not planning on locking the converter at WOT and i dont have a Tbrake. That was along time ago sooo i could be remembering wrong.
Old Oct 20, 2014 | 07:48 PM
  #587
smokeshow's Avatar
Mod with training wheels
If you look at the forward hub, its a pretty brittle looking piece. That really should be the first upgrade. As for the shafts, you have to consider what the shafts experience... The input shaft at maximum engine torque is only operating in a short RPM range, basically whatever your shift extensions are. But the intermediate shaft experiences more instantaneous changes in RPM, and that's what breaks shafts. So that's why that shaft is what is upgraded first. Also, stock48 has run 1000hp through his stock input shaft for the better part of a decade now
Old Oct 20, 2014 | 07:59 PM
  #588
Bumpers's Avatar
I thought that may have been the sonic boom when you break the sound barrier?
Old Oct 20, 2014 | 08:01 PM
  #589
oakley6575's Avatar
Yep I'm the same way, thats why I was asking. I thought you had build your 4L80e before gilbert did it..? Or am I mistaken?
Old Oct 20, 2014 | 08:19 PM
  #590
Atomic's Avatar
I originally bought it from performabuilt, then when it didnt work sent it to Gilbert, then when I wore out the clutches, I had blake rebuild it, so now its my turn.
Just got the trans out, input shaft about half an inch of axial play and spins smoothly and freely, I can tell the other end isnt attached to anything.
