I hope I'm not late for work!
Old Oct 20, 2014 | 08:33 PM
  #591
GMCtrk's Avatar
Originally Posted by smokeshow
If you look at the forward hub, its a pretty brittle looking piece. That really should be the first upgrade. As for the shafts, you have to consider what the shafts experience... The input shaft at maximum engine torque is only operating in a short RPM range, basically whatever your shift extensions are. But the intermediate shaft experiences more instantaneous changes in RPM, and that's what breaks shafts. So that's why that shaft is what is upgraded first. Also, stock48 has run 1000hp through his stock input shaft for the better part of a decade now
Ya, I wasn't including the forward hub but that should be upgraded. I've got the billet input shaft and forward hub. Stock intermediate and output shafts.
If you don't lock the converter at WOT the stock input shaft is probably ok, but I didn't want to leave anything to chance. The stock input shaft is weakened due to the oiling hole. The stock TH400 input shaft doesn't have this hole and is significantly stronger than the 80e piece.
Old Oct 25, 2014 | 02:36 PM
  #592
Atomic's Avatar
I have a gauge for that
Well todays project:
Made a rig so I can put the trans on an engine stand and spin it, better than spending $150 for a bench mounted one. Flexes a little when upright, but thats ok...
Funny how fast the pan fills with clutch material
Well this looks like an issue...
Old Oct 25, 2014 | 03:01 PM
  #593
1FastBrick's Avatar
Custm2500's Rude Friend
Better get some JB weld...
Was that a stocker?
Old Oct 25, 2014 | 03:27 PM
  #594
Whats the plan? You gonna build it yourself? My trans has been with Gilbert for over 5 weeks...supposed to be a 2 week turnaround LOL!!!! I will try to build my own again, I had the big snap ring and the smaller swapped on the trans I sent Gilbert. It popped out of the groove and caused a failure.
Old Nov 1, 2014 | 10:42 AM
  #595
Any updates? Boy have i had some shitty luck with my trans!
Old Nov 1, 2014 | 10:49 AM
  #596
Atomic's Avatar
Got the trans apart in the garage and have the new shaft on the table. Directs and forwards looked really good but intermediates are toast. Should hopefully have it back together this week sometime.
Old Nov 1, 2014 | 03:31 PM
  #597
How many clutches are in your direct and intermediate setup?
Old Nov 1, 2014 | 03:35 PM
  #598
BlackGMC's Avatar
Resident Retard
Before you out everything back together test fit you new input shaft into the torque converter. A friend of mine bought a billet shaft the other day that would not fit. He ended up buying a TCI billet shaft that worked.
Old Nov 1, 2014 | 05:28 PM
  #599
smokeshow's Avatar
Mod with training wheels
Had that issue with my billet input shaft. Just needed to file down the tiny burrs on the splines.
Old Nov 3, 2014 | 07:09 AM
  #600
Atomic's Avatar
Yea I talked to Gilbert and he mentioned I may need to do that, no big deal.
Forwards:
Directs:
Intermediates
