I hope I'm not late for work!
Old Mar 15, 2014 | 12:06 PM
  #341
BlackGMC's Avatar
Resident Retard
Why dual wastegates? Is that to control boost creep?
Old Mar 15, 2014 | 12:21 PM
  #342
Atomic's Avatar
I have a gauge for that
To control boost at all...the least I can run now is like 20psi, I would be fine with 6 or 7.
Old Mar 15, 2014 | 12:43 PM
  #343
BlackGMC's Avatar
Resident Retard
What size gate do you run now?
Old Mar 15, 2014 | 01:07 PM
  #344
oakley6575's Avatar
Cough..bullshit..cough..cough
Old Mar 15, 2014 | 08:18 PM
  #345
Atomic's Avatar
Single 50mms right now....Will be dual 50s
Old Mar 15, 2014 | 09:05 PM
  #346
cpolaris502's Avatar
Pretty sure I'm going to need to run dual waste gates on mine too. I have the trick manifold which I think is only a 38mm waste gate flange. I have a feeling it wont let me run much below 10psi if I ever wanted.
Old May 27, 2014 | 08:59 PM
  #347
Atomic's Avatar
Well finally got the truck back after having the new pipes made. Dual 50mm gates dumped by the passenger wheel. Completely divided setup right up to the turbo, and the exhaust housing is divided as well. EGT is in the driver side. I have gone back and forth about ceramic coating and wrapping and the way I see it the ceramic coating really just helps with corrosion and not heat rejection. Everything is now 306 stainless except for the cast manifolds. No welds on those so I am not worried about those corroding. Manifolds will be double wrapped and everything else will be wrapped once.
You guys that dont wrap you pipes, I dont know how you deal with all the heat. Mine gets so hot I cant hold my hand under the hood.
Took one test drive once I drove it 2 hours home to test out the functionality, but it got cut short because a plug wire wasnt on the whole way and literally fell off the plug. With 6psi springs and no reference on the gate it held boost to around 10psi, so with reference it should be 5-6 so perfect. Lag seems to be less but I havent thoroughly tested it yet.
I plan on moving the battery back to the stock location since that corner needs the most weight. Also plan on possibly making a better bracket for the coils.
Old May 27, 2014 | 09:13 PM
  #348
Chevy_King1500's Avatar
looks good! so everything is back together?
goals?
Old May 27, 2014 | 09:32 PM
  #349
black00chev's Avatar
Slowest turbo build ever!
looks badass my friend!
Old May 27, 2014 | 10:46 PM
  #350
thunderwagen's Avatar
Looks good man any pictures of it in the truck?
