I hope I'm not late for work!
Old Apr 30, 2020 | 12:04 PM
  #1971
BigKID's Avatar
Originally Posted by Atomic
I scientifically straped myself in and flailed about as much as possible
Visualizing that made me chuckle a bit.
That gives a lot of clarification to the construction and attachment of the outside bracket, thanks. I have no doubt it is much more secure that the stock GMT800 belt-in-seat restraint in the event of a crash.
I will be keeping an eye on this. I want to do a harness bar like Steve-O had done but am having a hard time finding someone locally to do it. I have a feeling I will need to raise the bar above the bottom of the back glass for proper fitment though. I won't know for sure till I get the new seats in but my shoulders are well above the back wall with the stock seats.
Old Apr 30, 2020 | 01:01 PM
  #1972
Atomic's Avatar
I have a gauge for that
I even got a friend of mine to do the same thing and he didnt budge either
I intentionally made mine to be right under the glass so you cant really see it. Its not that visible sitting in it either, the bars are completely out of the way. I dont know if I have seen steve-o's?
Old Apr 30, 2020 | 01:43 PM
  #1973
BigKID's Avatar
Its basically a 4 point roll bar without the hoop going to the roof and the down bars shaped for easy entry. I would likely make it a little taller and add some diagonal cross braces.
From his build thread...
https://www.performancetrucks.net/fo...8/#post5311898
https://www.performancetrucks.net/fo...8/#post5403528
Old Apr 30, 2020 | 04:57 PM
  #1974
Atomic's Avatar
Ah, yea, little bit more involved and not sure those curved outside bars are any stronger than my setup honestly. Hopefully no one has to find out haha.
Old Apr 30, 2020 | 05:06 PM
  #1975
T-RevMotorsports's Avatar
5 Year Member
That harness bar setup turned out bad *** man.
Old May 4, 2020 | 01:54 AM
  #1976
Atomic's Avatar
Well got everything buttoned up and went to try to take a test drive but transmission is not happy. I can feel it go into gear (reverse, and forward gears) but the vehicle doesnt move with any throttle input (revs like in neutral). Fluid level is good, checked 100 times. Pressures are idle/2k, park: 110/140, drive 120/150, reverse 120/190. If I put the rear on jack stands and put it in gear the wheels will turn, but I can literally hold it still with my hand so its just barely dragging along in the trans. I really hate pulling transmissions and am hoping its something easy I can see by dropping the pan instead of pulling the whole thing out again. Trans was rebuilt because of a broken sprag (wouldnt make the 2-3 shift), but everything was fine otherwise.
Old May 4, 2020 | 11:01 AM
  #1977
RA62025's Avatar
Banned
Yea passenger seat fits fine, see the last pic above, everything is installed there.
Hey Richard,
Would you know if the middle jump seat would fit with this setup? Or would you have to take it out or get a center console?
Old May 4, 2020 | 12:05 PM
  #1978
Atomic's Avatar
I dont know for sure, but a middle jump seat sure would look weird between 2 racing seats
Old May 4, 2020 | 03:50 PM
  #1979
1FastBrick's Avatar
Custm2500's Rude Friend
So what your saying is, No matter how hard you try, your going to be late for work...
Old May 4, 2020 | 07:06 PM
  #1980
terravast4's Avatar
