I hope I'm not late for work!
Old Oct 21, 2019 | 09:11 PM
  #1951
Atomic's Avatar
I have a gauge for that
Over 9000 i'd bet
Old Oct 21, 2019 | 09:27 PM
  #1952
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Atomic
I think you guys really underestimate how stiff this damn hose is. I can jump up and down on it at 260lb and still not crush it. That other hose is appealing since I need to make a couple tight bends though, seems to be more flexible than what I have.
Over 9000 i'd bet
So your telling me it doesn't deform at all??? Where did you get it from ?
Old Oct 21, 2019 | 11:17 PM
  #1953
Atomic's Avatar
It does some, but doesnt compromise at all. Home depot, sold in a 2 ft section. Its going to be super short piece between all the fittings, maybe 6-8" long.
Old Oct 22, 2019 | 06:08 PM
  #1954
Jonblarc7's Avatar
I’ve used the hose atomic posted for ballast systems in my wakeboats. I’ve hooked it up to 1200 gph pumps and it doesn’t suck flat.
Old Oct 23, 2019 | 02:30 PM
  #1955
bottledls6's Avatar
Iv been researching these electric pumps. CWA200/400 for the water pump , volvo power steering motor, an the tesla A/c pump, remote mount these along the frame and out of sight. Each will more an likely have its own PWM unless I can find something to run all three. Havent gotten that far lol. so wonder if that cwa200 is good enough to swap out for my water pump.
Old Oct 23, 2019 | 02:35 PM
  #1956
1FastBrick's Avatar
Talking
FWIW, the Prius also uses an electric water pump. Just not sure on the model.
Old Oct 23, 2019 | 02:44 PM
  #1957
Atomic's Avatar
I would go straight for the 400, and yes I'm sure it would be fine to use as a main radiator pump. It's big, about the size of a coffee can.
Old Oct 23, 2019 | 03:04 PM
  #1958
Jeebalow's Avatar
Hmmm, that would solve your water pump pulley issue as well. Any idea what kind of current draw you'd have with all 3?
Old Oct 23, 2019 | 08:32 PM
  #1959
Atomic's Avatar
The CWA200 is up to 15amps and the CWA400 is up to 30amps I believe.
Old Oct 28, 2019 | 11:00 AM
  #1960
bottledls6's Avatar
35 AMPS plus two others drawing more on top of that... Wonder if id have to upgrade the charging system?
