I hope I'm not late for work!
Old May 4, 2020 | 08:33 PM
  #1981
Atomic's Avatar
I have a gauge for that
Ya got that right!
Old May 5, 2020 | 10:11 AM
  #1982
RA62025's Avatar
Banned
Originally Posted by Atomic
I dont know for sure, but a middle jump seat sure would look weird between 2 racing seats
Looks like I will be the only guinea pig. Lol
Old May 5, 2020 | 12:09 PM
  #1983
terravast4's Avatar
I yanked out my jump seat, I like the look much better, might put a floor shifter there
Old May 5, 2020 | 12:39 PM
  #1984
RA62025's Avatar
Banned
I would but both my daughters love going on rides in the truck
Old May 10, 2020 | 03:12 AM
  #1985
Atomic's Avatar
Looks like I may have found my issue...builder left out the overrun clutch retainer plate snap ring causing the OD sprag to not function properly
Old May 10, 2020 | 09:57 AM
  #1986
03sierraslt's Avatar
That will do it, and you have some low pressures.
Old May 10, 2020 | 01:53 PM
  #1987
Atomic's Avatar
I wonder if this would have resulted in the low pressure or if thats a separate issue.
Old May 10, 2020 | 07:00 PM
  #1988
Yes, depends what gear you have selected though.
Old May 17, 2020 | 11:47 PM
  #1989
Atomic's Avatar
Well got the trans fixed and back together. Replace the whole OD piston pressure plate thing as well as the sprag. That thing is tricky to install correctly. I deleted the 2-3 and 3-4 accumulator as well while I was in there. Still not sure I did the checkballs right but it shifts so thats all I care about. Took it for a test drive around the block and wow this exhaust is loud
Got a bath too:
Ready to party once the tracks open back up here
These turbos spool really fast which I think a lot of it is the downpipes, but at low speed and less than half throttle I am at 6psi+ in less than a second from the turbos (so 15psi+ total).
Second thing is the intercooler pump is a beast. I set it up so I can hook an outlet hose to the return fitting in the tank to drain it just by turning the pump on and it literally drained half the cooler (about 5 gallons) in about 10 seconds before I could walk around the truck. Its definitely moving some volume. I dont think there will be any advantage to running more than 50% honestly, the water temperature got up to the intercooler temperature very quickly, so the pump is doing its job. Now I just need to make sure I have plenty of ice on hand because it took 11-12gallons to 100F water in a couple of minutes of easy driving.
Old May 18, 2020 | 12:43 AM
  #1990
1FastBrick's Avatar
Custm2500's Rude Friend
Yes, but will you make it to work on time???
