I hope I'm not late for work!
Old Oct 8, 2013 | 06:01 PM
  #181
Atomic's Avatar
I have a gauge for that
I replaced the UCA bushings with the beltek kit so hopefuly I can get my alignment set up better now. What does everyone recommend for alignment setup specs? I dont do any curvy driving, just drag strip and highway...
As a side note, I bought a 20ton press from harbor freight and replaced the jack with a 20ton air jack....money well spent! I replaced all 4 bushings in probably an hour including taking them off and reinstalling them, pretty easy job!
1000 miles on the coilovers and still rocking!
Old Oct 8, 2013 | 07:07 PM
  #182
Chevy_King1500's Avatar
good deal! what did you pay for the press and jack? people say the jacks that come with are junk. I just replaced all the a arm bushings but took them to a shop because I don't have a press.
how much camber adjusting can you do with the stock parts?
Old Oct 8, 2013 | 07:24 PM
  #183
Atomic's Avatar
I ended up getting the press for 122 out the door and the air jack for about 80 out the door.
Just under the amount I need to get the alignment where it should be
Old Oct 8, 2013 | 11:14 PM
  #184
Blown06's Avatar
8 Second Truck Club
As much caster as you can get, no camber and about 1/8" total toe in. No bump steer.
Old Oct 18, 2013 | 01:30 PM
  #185
97_ek's Avatar
I had no idea you're in Huntsville, but I'd love to see this truck in person. I have a 2003 Silverado I got about a month ago to start playing with. Currently getting parts for a 6.0 swap to go in it. Anyways, there is a local forum that you might find interesting that is big into drag racing. It's called hsvracing.com. If you go there to sign up go ahead and get prepared for hazing of the new guy with "GF or wife's **** or GTFO" etc, but just ignore that and move on with your posts. There are some pretty good guys on that forum, and several legitimate street cars that are running in the low 6s and high 5s. As a matter of fact they are setting up a street car shootout coming up soon if you'd be interested in participating. I'm sure all of them would love this truck. Just ignore the drama haha.
Old Dec 22, 2013 | 09:30 PM
  #186
Atomic's Avatar
Havent updated in a while...
Went to the PT Jackson, MS meet and had some fun with this GTR that traps about 170mph in the 1/4.
https://www.youtube.com/watch?v=__ns...bJz5E7-rSqcNbA
I knew I would loose but sheesh that car is awesome.
I only got to make one pass...
https://www.youtube.com/watch?v=7C3X...bJz5E7-rSqcNbA
Damage ended up being...
Coolant tank:
Head and head gasket:
And turbine wheel:
The good news is the block and piston looks fine and the oil is clean.
I had the tank fixed, turbine wheel replaced, and head repaired by MPFab (guy who did my turbo pipes)
I also upgraded to the ARP CA625 head studs and 5/8 nuts on the recommendation of Brian at LME. There is a substantial size difference...dunno if it helps but it makes me feel better about it.
Fancy head studs...
I am working on getting everything back together now, and finally redid that annoying cable bracket...the new design is much simpler
Old Dec 22, 2013 | 09:43 PM
  #187
smokeshow's Avatar
Mod with training wheels
Head looks almost perfect now.
Old Dec 22, 2013 | 10:07 PM
  #188
Atomic's Avatar
Yea, Walker is a beast
Forgot to mention, a 116mph 1/8th pass in a 5000lb vehicle works out to about 1150rwhp...this turbo is good for around 1200hp so it looks like its right on the money!
Old Dec 22, 2013 | 10:50 PM
  #189
Koots's Avatar
**** those are some beefy head studs!
Should be nice and solid when it goes back together
Old Dec 23, 2013 | 12:28 AM
  #190
Spoolin's Avatar
GFYS and STFU
40 psi or bust now!!
