2009 Silverado ... another flipped Manifold build
Old Apr 6, 2016 | 04:02 PM
  #51
Mean Green z28's Avatar
11 Second Club
Originally Posted by Atomic
That MAF might be happier in a straighter section of pipe, like where you plan to put the BOV.
Just thought you'd wanna know that you were exactly right! The MAF readings at idle were way off from expected, probably due to the bend right before the sensor. Will be moving it to the straight section before the bend when putting this all back together. Hopefully that'll fix the readings or at least help.
Old Apr 6, 2016 | 04:55 PM
  #52
SSnation's Avatar
Interesting, not bad!
Old Apr 6, 2016 | 07:48 PM
  #53
11 Second Club
Default 2009 Silverado ... another flipped Manifold build
Giggidy... painted and mounted MAP sensor directly instead of off a Tee and also set up vacuum ports directly off of manifold to keep things a bit neater at the back of engine.
Now need to order the MAC boost solenoid to work with my AEM boost gauge/controller and wire that up.
Old Apr 8, 2016 | 09:37 PM
  #54
11 Second Club
It's one hit after the other for me!
the heads that the shop had sent to the machine shop were 853 heads that have the notch in them. They already milled the heads and swapped the valves and springs etc. without filling the notches, doh! So welding the notch is gonna require another cleanup cut ... and each cut is gonna reduce chamber volume and increase compression.
So my LS9 gaskets aren't gonna work with the notch, cos with my luck, they will leak.
My two options are to get the notch welded and do a cleanup cut or use Fel-Pro 1161 gaskets that are designed to work with the notch and send the LS9 gaskets back (cheaper) ... ugh ... either way, the truck will be down longer
Old Apr 14, 2016 | 07:00 PM
  #55
11 Second Club
Got heads back from machine shop for the second time. This time they were welded up and milled for a cleanup cut and cc'd. They came in at 64cc and we're shooting for 10:1 ... but the pistons installed are wrong and are actually Wiseco 6cc domed ... doh. No dough to pull engine now, so just ordered custom Cometic gaskets to get me back down to pump gas levels. Ugh...this is really frustrating.
Old Apr 15, 2016 | 09:17 AM
  #56
DAMN IT!
Old Apr 15, 2016 | 12:25 PM
  #57
kainedogg's Avatar
Man, I was loving this thread, now I am as upset as you are OP. I was following along for motivation to finish my C10.
You'll get it sorted out soon bro.
Old Apr 16, 2016 | 06:46 PM
  #58
11 Second Club
Well, just waiting for gaskets now...takes about 3-4 days to make and ship I was told by Cometic, so I guess it'll be a week or so.
So, I put everything away and did some spring cleaning around the garage today.
Also go into the engine bay with a brush, rags and carb cleaner and went to town cleaning the deck surface and all the piston tops, they're all squeaky clean now. My neighbor gave me a wierd look when she saw me IN the engine compartment haha
Old Apr 19, 2016 | 06:45 AM
  #59
11 Second Club
So I kept at it and took the valley cover off ... holy crap it looked like poop in there!
Took kitchen towels and went at it again ... it's all clean in the engine as I can get it. Took valley cover pcv system completely apart and cleaned it all and sealed everything back up. What a mess...
Old Apr 19, 2016 | 10:16 AM
  #60
Choda's Avatar
Nice job and way to stick with it.
