2009 Silverado ... another flipped Manifold build
Old Mar 11, 2016 | 03:03 PM
  #21
Atomic's Avatar
I have a gauge for that
That MAF might be happier in a straighter section of pipe, like where you plan to put the BOV.
Old Mar 11, 2016 | 06:21 PM
  #22
Mean Green z28's Avatar
11 Second Club
hmmm thanks for the tip, I could put a straight pipe where it is now and swap the elbow for a 4-4 and put it just before the bend so it can get some good straight laminar flow. The blowoff can be right by the battery
Got the inlet side of the intercooler done too...
ofcourse this bit is about to change a wee bit to put the MAF before the turn
Old Mar 11, 2016 | 06:39 PM
  #23
Choda's Avatar
i like it. Keep up the good work
Old Mar 13, 2016 | 04:56 PM
  #24
11 Second Club
Managed to mount the Blowoff Valve and also run the oil supply and return lines ... $165 for two fabbed up lines from Parker!
Old Mar 14, 2016 | 09:41 AM
  #25
11 Second Club
Also spoke to my buddy who'll be helping me tune it and he said just leave the MAF where it is for now and we'll see how the truck likes it. If it turns out to be a problem with erratic readings, well move it. I just want to have the least amount of joints and clamps.
Old Mar 14, 2016 | 09:50 AM
  #26
Atomic's Avatar
Then get rid of the MAF entirely
Old Mar 15, 2016 | 08:52 AM
  #27
11 Second Club
So was able to get wastegate location sorted out some. Just need to get a bellow/flex tube short enough to fit to finish up the final piece of pipe and finish welding up the merge.
charge pipes done and ready for beads to be rolled on
cardboard tube to help with wastegate placement
wastergate location setup
cardboard tube kinda worked out good
Cardboard tube slid on top of metal tube
cut!
Old Mar 17, 2016 | 09:04 PM
  #28
11 Second Club
All major fabrication done, front grille is back on!! It's the final stretch. Started insulating the A/C and Coolant lines and relocating the Coil packs just a bit higher and got the MSD 32079 wires so that I can use a 90° boot to route the wires forward and down.
DONE!
Downpipe connected to rest of exhaust
Started wrapping...
Old Mar 18, 2016 | 01:27 PM
  #29
settlemoore's Avatar
Just curious, who's gonna be doing your tuning?
Old Mar 20, 2016 | 06:01 PM
  #30
11 Second Club
My buddy at Arundel Performance Inc. (Also known as F-body Central).
The truck has put down 520rwhp on the old setup on 12psi on a Mustang dyno with the 4L60E ... hoping for some decent numbers but would settle for a badass street truck with good manners.
