2009 Silverado ... another flipped Manifold build
Old May 12, 2016 | 01:16 PM
  #71
gravedigger472's Avatar
Originally Posted by Mean Green z28
So you worked on timing after?
welll, let me clarify. before doing any tuning and getting into boost, we made a base timing table so it would pull a ton of ignition timing (to about 9-10*) when the truck would be in boost. This will ensure the truck would safely run while dialing in fuel mixture, not having to worry about detonation. After we got the VVE and mass airflow dialed in, the truck would deliver the fuel mixture we commanded in closed loop and PE modes, so there is no worry about leaning out.
Then, we slowly added timing back in a little at a time, (while on the dyno) measuring power gains and seeing what the truck liked.
Old May 12, 2016 | 04:38 PM
  #72
Mean Green z28's Avatar
11 Second Club
Ah gotcha..thanks
Have been following the EFI Live VVE tutorial and logging some runs. Still rich past about 3k. Have a 3.5psi spring in the wastegate to keep boost low but may put a smaller one in.. will slowly up the boost as the lower end of the table is cleaned up by using the boost controller (AEM TruBoost).
Old May 12, 2016 | 08:06 PM
  #73
11 Second Club
BTW, do you by any chance remember what MAP and RPM boundaries you'll used? I feel like I need to more the boundaries more into the boost range than the off boost range, but then most driving happens in off or light boost.
Old May 13, 2016 | 09:10 AM
  #74
you mean the scaling of the VVE table?
my manifold pressure goes from 15 to 255 kPa alternating between 7 and 8 kPa increments, and RPM goes in 200 rpm increments between 400 and 6,400rpm, so there is plenty of resolution in the table for vacuum and boost areas.
if you are asking about the tables "zone RPM boundaries" and "zone MAP boundaries" we didn't change those from stock
Old May 13, 2016 | 05:13 PM
  #75
11 Second Club
Default 2009 Silverado ... another flipped Manifold build
Yeah I meant the boundary tables. Since mine pretty much makes boost from 2k we had to modify the table so we'd have more boundaries when in boost.
Old May 15, 2016 | 09:45 PM
  #76
11 Second Club
Very slowly getting the fueling figured out. Put in a 3.5psi spring and set up the controller to its 90% duty cycle max and only got about 7psi out of it. Then set it up different which would let allow more ... 11 psi came super quick! Didn't expect it lol. Had to turn it down until we really start dialing things up. May go for a 4-port solenoid eventually instead of the 3-port ... I somehow feel there needs to be a vent.
Old May 17, 2016 | 09:24 PM
  #77
11 Second Club
So we may have figured out a fueling issue we kept having if I stomp on the gas vs. get on it gradually ... never thought of looking in the trans tune and the torque reduction tables. Some of it was almost 40% !!! Have yet to do a run/log but hopefully it let's us make some progress.
Old May 21, 2016 | 10:52 AM
  #78
11 Second Club
Still fooling around with tune. Had crazy lean spikes trying to do it the conventional way. Now the tune is scaled and we don't see the crazy readings we had, so I guess we're making progress. With my time and my buddies combined, we should have just taken it to a shop and had them go through it from the start. However, I'm completely tapped out right now and another 500-600 isn't in the budget. Maybe on the divorce budget if I did spend it, lol
Old Aug 6, 2016 | 11:45 AM
  #79
11 Second Club
Not a high dollar build as others but it's still boing along ... in the process of getting a 3200 stall converter and the Tru Cool 40k cooler to wake this bitch up!
Currently have it set at 15psi using an Innovate SCG -1 widebang/controller ... loving this controller a bit more than the AEM TruBoost I had before!
Feed
Aug 10, 2017 08:54 AM
cfaluck13
Oct 16, 2016 04:05 PM
Chevy6.Zero
Jan 13, 2016 04:00 PM
melon07
Jan 12, 2016 07:00 PM
WS6HUMMER
Dec 21, 2015 12:54 PM
