2009 Silverado ... another flipped Manifold build
Old Apr 1, 2016 | 06:29 AM
  #41
Mean Green z28's Avatar
11 Second Club
Well looks like I'll be pulling the heads this weekend. Its peace of mind and I don't wanna blow up the turbo with a diluted oil mixture. After reading up a bit, got some LS9 head gaskets coming and will also be using copper spray as done by some for a bit of additional sealing. Now just wondering I wanna coat just the two sides or between each layer also like a few have done. Decisions decisions. ..
Old Apr 1, 2016 | 06:34 AM
  #42
Choda's Avatar
Congrats man. My catch can has filled w moisture before too. I was also worried but it never turned into anything bad.
Old Apr 1, 2016 | 06:45 AM
  #43
11 Second Club
Default 2009 Silverado ... another flipped Manifold build
Well yeah that was my initial thought. But its got to the point where I'd leave home and get to my buddies shop and have a bunch of water that drains out. Then almost immediately turn around and dive to another shop and again have water draining out. And when I mean draining out, it's not a drop or two, it's a small stream that flows out the valve and the filter on top of the catch can is drenched. Fml
Atleast it's got ARP studs so things may be a bit easier lol
Old Apr 4, 2016 | 04:03 PM
  #44
11 Second Club
Well took some time and pulled the heads today. Def a lot of "milk" in there ... taking heads to the machine shop to get pressure tested etc for good measure. heads only have mild chamber work and larger valves installed, wish I had the $$$ to put some better heads on while I'm at it
As it sits
Was able to take the turbo kit out as one big piece ... giggity
Old Apr 5, 2016 | 09:46 AM
  #45
Choda's Avatar
Damn sucks to hear. My simple head job and new spring install was 270 bucks total. They took 5 thou off for the resurface
Old Apr 5, 2016 | 12:56 PM
  #46
11 Second Club
dropped it off and asked them to give it a full checkup and to mill if it was warped ... my bank account is getting pissed off as much as the wife (I've only just made the first payment on the truck and I've worked on it longer than I've driven it). Hopefully, this is the last big issue and the next phase (tuning) goes off without issues...
Old Apr 6, 2016 | 09:47 AM
  #47
11 Second Club
Well I'm f*cked ... cracked head
Old Apr 6, 2016 | 11:28 AM
  #48
GM1697's Avatar
damn.... remortgage the house, get some quality heads
Old Apr 6, 2016 | 11:54 AM
  #49
settlemoore's Avatar
You on facebook? I'd try ls1heads of Maryland...someone probably has something laying around for cheap, bunch of dudes on there
Old Apr 6, 2016 | 11:56 AM
  #50
11 Second Club
Got a set of stock 5.7 heads sent over to get the valves and springs swapped over. It'll lower the comp by a 1/4 point supposedly but nothing a bit of timing and boost can't fix. Still... Def. not a happy camper right now.
Using the extra time to clean up bay and paint some items etc.
