5.3 to forge or not to forge
Old Jun 28, 2015 | 06:51 PM
06boosted5.3's Avatar
Default 5.3 to forge or not to forge
so I in the midst of building a 76mm 5.3 that I will max out around 700rwhp. I have seem many say that factory rods pistons will live. however I plan to beat this thing. so my question is will it live or forge it? I was looking at k1 rods and weisco pistons on a factory 5.3 crank. any oinions?
Old Jun 28, 2015 | 07:56 PM
terravast4's Avatar
if you got the money build it...if not you will probably be fine
Old Jun 28, 2015 | 09:53 PM
Chiphead's Avatar
If the tune is right it'll live for awhile. But if you have a tuning mistake or something, those stock pistons will bust a ring land. Next to go after that would be the stock PM rods. I'd do a forged rotating assy if you really wanted to live long-term.
Old Jun 28, 2015 | 10:30 PM
George C....'s Avatar
Formerly ScreamingL
if weak rod motor then 700 -750 is safe limit
if strong rod motor then 700 is plenty safe, ive made over 1000 rwhp with stock internals
Old Jun 29, 2015 | 08:26 PM
what do you mean by that ? I have a 2005 avalanche 5.3 lm7 I plan on k1 bolts, cam and springs, and setting the ring gap a little bigger other than that id rather not touch it.
Old Jun 29, 2015 | 10:11 PM
Formerly ScreamingL
05 motor is strong rod...
Old Jun 30, 2015 | 09:18 PM
cool thanks for the info m
Old Jul 1, 2015 | 10:07 AM
Chiphead's Avatar
Are you guys calling the floating wrist pin rods the "strong" rods? I used them in my 5.3 build with the ARP bolts and did not have to have the rods resized.
Old Jul 2, 2015 | 11:41 AM
bobfig's Avatar
from what i understand the 05+ motors have a stronger rod the then 04 and earlier.
Old Jul 2, 2015 | 05:21 PM
gamble686's Avatar
If you compare the rods side by side the newer rods are much much beefier.
Blwn99x
Sep 11, 2015 09:27 PM
97gmc
22
Sep 8, 2015 10:56 PM
11MPG
Sep 8, 2015 04:52 AM
screaminian47
Sep 7, 2015 08:20 PM
USMCvet0311
Sep 4, 2015 09:43 PM
