On3 turbo kit, which turbo?
My set up is this....
5.3 stock long block(for now)
BTR Stg 3 truck cam 218/224 .553
4l80e 4000 stall
3.42 gear(going to 4.10 soon?)
Rcsb
Nx wet kit
Kit comes with 70mm. Was looking at the 78/75 upgrade option. Goal is 600ish whp.
My truck might get heads and intake before a turbo happens due to it being a project vehicle for an online webzine. I am sorta knowledgeable about boost but I would appreciate any input from the pros on here. Thank you.
4l80e 4000 stall
Rcsb
Nx wet kit
I would say the 76 mm unit. I have the 78 currently on my personal rig and am NOT impressed. I may put a 76 unit on it instead. I have built 2 similar 6.0 motors, and a 5.3 also with both the 76 and 78 turbos. The 76 is more responsive and I dont think you could tell a difference in power up top otherwise. Bigger isnt always better IMO. If you have a super loose converter the 78 would spool just fine. Error on making it more drivable.
IMO, going "big with room to grow" on a turbo build is the biggest single mistake people make in a turbo build. Put the right turbo on it for what you have NOW and it will be the best it can and for most people, that's good enough! lol
Turbos are not that expensive and have good used resale value. So upgrading later when (if) you do need bigger, it's not that much money to upgrade the turbo it's self.
IMO, going "big with room to grow" on a turbo build is the biggest single mistake people make in a turbo build. Put the right turbo on it for what you have NOW and it will be the best it can and for most people, that's good enough.
My thought is also if I can make the same power with a 78@8psi as a 70@14psi I would pick the larger. My last turbo car was in 1997 so I'm rusty lol
I went with the 70mm. My goal is 600 rwhp at around 16 psi or so before its maxed out, 93 octane, and meth. Might not make it to 600 but should be close enough. Plus I want good spool for street driving. I am looking for something fun to drive and come into boost quick. Once I get the feel for that and want more, I'll focus on making more power and running faster times and get a Borg. I'm sure I'll have traction issues with the 70mm anyways.
