Driveshaft recommendations.
Old Jan 5, 2009 | 10:10 PM
KA41's Avatar
Default Driveshaft recommendations.
I have a an 07 crew with a 5.3, 3.42 gears. I will be installing a built 6.0 with a maggie, 3.73 gears, and probably a 3000 stall. What I would like to know is what I should do about the driveshaft. Anticipated rwhp is going to be in the 550 range. Again this is a crew cab.Thanks.
Old Jan 6, 2009 | 07:42 AM
litreddevil's Avatar
Banned
leave it alone
Old Jan 6, 2009 | 02:01 PM
KA41's Avatar
So you are saying a stock driveshaft is capable of 550 hp.
Old Jan 6, 2009 | 02:10 PM
KySilverado's Avatar
I can think of 4 or 5 trucks here that run the stock shaft with that HP and more.
Old Jan 6, 2009 | 02:11 PM
BLACK04VHO's Avatar
yes, it will be fine.
Old Jan 6, 2009 | 02:12 PM
BLACK04VHO's Avatar
your tranny will be the problem.
Old Jan 6, 2009 | 02:31 PM
KA41's Avatar
I have that taking care of. Tranny is definitely going to be beefed up.
Old Jan 7, 2009 | 12:31 AM
rgvsierra's Avatar
it will be fine, but start taking it over 100 and its gonna fly out from under you. seen it happen way to many times on 07+Crew cabs.
Old Jan 7, 2009 | 12:43 AM
Mr. Sandog's Avatar
At minimum, find a driveline shop near you and get the stock one removed, inspected, and high-speed balanced. If the stocker can't tolerate what you will be putting through it, the driveline shop should be able to tell you that.
Old Jan 7, 2009 | 01:18 AM
lucky77's Avatar
Banned
that ' OEM driveshaft will blow 'sonner or later' espeacilly over 100MPH . if i were you get a build shaft' with 1350 slip yoke / 1350 u-joints . . besides if they blow. they take parts with them .. and you could damage ur rear-End < mine blew after 130mph . .
