Did the 05 gto's come with a ls6 intake
Old Mar 9, 2007 | 01:11 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Did the 05 gto's come with a ls6 intake
Does anybody know, I ain't to found on what intakes acame on what. If it didn't does it flow as good as the ls6?? Also did all the 05's switch to returnless fuel systems.. or just the trucks
Thanks Much JOHN
Old Mar 9, 2007 | 01:54 PM
Ferocity02's Avatar
05 GTO's have an LS2 intake. The LS2 is similar to the LS6. However, the LS2 intake uses a 4-bolt TB while the LS6 uses a 3-bolt. Both will bolt to LS6/LS1 heads though.
Old Mar 9, 2007 | 02:05 PM
Ditto
Old Mar 9, 2007 | 03:35 PM
tdrumm's Avatar
The LS2 TB is 90mm DBW which would require some mods to get working or the theoretical NW 90MM unit that is coming out. The guys on ls1tech seem to have found that the LS2 intake does not make as much power as the LS6 despite the bigger TB.
Old Mar 18, 2007 | 12:34 AM
RotaryResurrection's Avatar
If I have an lq4 with 3 bolt DBW TB and want to switch to an LS series intake, could I simply get the ls2 intake and 3 bolt DBW throttlebody and have it plug and play (the TB that is) or are they electrically different? I know there are fuel rail/injector/accessory drive mods to make the LS series intakes fit the truck motors, I am just asking about the TB compatibility.
It may be a moot point, as it seems there are NEVER any LS series DBW throttlebodies available, only manifolds.
Old Mar 18, 2007 | 07:40 AM
tdrumm's Avatar
The 90mm Ls2 throttle bodies are not plug and play onto a DBW truck. They can be made to work using an adapter harness from Speartech and a new TAC module from an 02 truck. Doing it this way will work, but the TB blade only opens 88% or so. The stock 3 bolt pattern 78mm truck DBW throttle body will not bolt to a LS2 intake without making an adapter, but why bother bolting a 78mm TB to a 90mm intake?
Old Mar 19, 2007 | 02:36 AM
Wow, thanks for the info. Glad to find that people are helpful on this board and know their **** like we on rx7club. I have a general idea of what I want to do with this truck, but I have little idea about parts year/model application and interchange like some of you guys.
So how about an ls6 manifold with my truck TB...equally as pointless?
Does the ls6 stock DBW TB work on a truck?
Old Mar 19, 2007 | 06:01 AM
tdrumm's Avatar
A LS6 DBW doesn't work on our trucks either, but the stock truck DBW is the same size and works on a LS6 intake manifold. There's a few guys running this setup.
5.3Okasai
Mar 9, 2022 01:07 PM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
lxcoupe
Sep 2, 2015 12:58 AM
RONIN LSX
Aug 11, 2015 12:03 AM
