Z06 Cam in 4.8L
Old Feb 27, 2006 | 12:12 PM
LS1GTA's Avatar
Default Z06 Cam in 4.8L
What type of powerband would this cam give to a 4.8L. Would it still be good for daily driving?
Old Feb 27, 2006 | 12:53 PM
98TAauto's Avatar
mainly mid and upper rpm power... you would probably loose some low end without a stall
it would drive and idle fine, but if you tow or use 2000rpm and below alot then you might suffer their untill you got a small stall
Old Feb 27, 2006 | 11:04 PM
FarmerBeau's Avatar
Sexy Party Mod
Yea, its a great cam. Very stealthy and pulls hard up top.
Old Feb 28, 2006 | 08:59 AM
EvilChevy's Avatar
Question is where can i get a LS6 Cam for my 4.8... The other engine is the hot Rod engine and wouldn't it be a good idea to Add LS6 heads in this combo.
Old Feb 28, 2006 | 09:13 AM
ktmrider's Avatar
The 01' Z06 cam has less lift and more LSA so it impacts low end performance less than the 02+ cam does. The obvious trade off is top end performance. The 01' is cheaper and can be used with the stock truck valve springs on a budget ( 0.525 vs 0.550 gross lift ).
Old Feb 28, 2006 | 09:14 AM
FarmerBeau's Avatar
Sexy Party Mod
If you are gonna throw ls6 heads on top of it all, first you are gonna have to get the heads milled a bit in order to get the compression back up due to the ls6 head having a larger combustion chamber. As for adding a ls6 cam with those heads, yea it would work ok and produce power but i would look into a different cam that would take full advantage of the flow numbers those heads produce.
You can get it through SDPC (sponsor>>>>>) for like $250 with springs in a kit. Just give them a call! I almost went that route but opted for something a bit more potent.
Old Feb 28, 2006 | 09:31 AM
SS_bnoon_SS's Avatar
I got my '02 LS6 cam/springs/pushrods for $150 shipped used (12,000 miles)off of a Corvette forum.
Old Feb 28, 2006 | 11:58 AM
getchusum99's Avatar
i was lucky enough to get mine for free. how bad will it effect my low end performance, because i do tow alot and off road alot more. i have the 02 cam as well and teh springs
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
lxcoupe
Jul 30, 2015 02:42 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
