pushrods?
Old Feb 28, 2006 | 09:09 AM
lilgapainter's Avatar
Default pushrods?
im installing a vinci 062 cam shortly. what length pushrods do i need? my heads are going to be milled 30. using stock valves and rocker arms. the specs of the cam are 210 218 .551 .551 112 lsa.
Old Feb 28, 2006 | 09:18 AM
tdrumm's Avatar
I have the same cam and have Thunder Racing 7.4" pushrods. Any 7.4s will work.
Old Feb 28, 2006 | 09:21 AM
FarmerBeau's Avatar
Sexy Party Mod
i thought you would have to use 7.35" if you had your heads milled any more than .020" Im pretty sure i would use those rather than the stock length of 7.400"
Old Feb 28, 2006 | 09:34 AM
SS_bnoon_SS's Avatar
Many aftermarket cams require longer pushrods because of a smaller base circle. You have to check with the cam manufacturer to be sure. You should also check yourself with a pushrod length checker before ordering them.
Old Feb 28, 2006 | 11:33 AM
tdrumm's Avatar
Doh! I missed the part about the milled heads. You are correct, I would run 7.35s in that case.
Old Feb 28, 2006 | 02:51 PM
but u have to 7.425" rods if u go with an aftermarket cam due to the base circle...thats what i read on this very forum.
so adjust the .05 for the milled heads adn you'll need 7.420..lol
SS94S10
Jan 3, 2019 01:57 PM
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
