Ebay/OBX style header install w/plenty of PICS (LONG, but detailed)
Old Jun 17, 2010 | 04:28 PM
  #151
Sales2@Texas-speed's Avatar
Former Vendor
I didn't read the entire thread so excuse me if this has already been covered, but I wanted to throw out there that header primaries are measured outside diameter, not inside. So if they measure 1 3/4" outside, then that's what they are and why they are advertised as such. Folks can go measure their Pacesetters, ARH, Kooks, etc to verify that one.
Old Jun 17, 2010 | 05:38 PM
  #152
PathfinderJr's Avatar
Negative. Primaries are supposed to be measured using the i.d. for consistency from manufacturer to manufacturer. If some company is actually calling out o.d's, then shame on them because that is incredibly misleading.
Think about it. How do you have a constant measuring stick across the spectrum of various header manufacturers if everyone uses a different thickness material for their tubing. Sure two companies may have the same o.d. of 1-3/4" but if the material thickness is different between them, then the i.d. will be different and the subsequent performance between them if used on the same engine will be varied.
Long story short, primary tube sizing should be according to the i.d. of the tube. So before anyone orders some headers, check to be sure.
When I used to play with SBC stuff, headers were called out according to their i.d. Newer gen headers shouldn't be any different.
Old Jun 17, 2010 | 06:29 PM
  #153
hirdlej's Avatar
Really??? The inside diameter of the 1 7/8" headers I ordered are actually 1.875" with my vernier caliper.
Old Jun 17, 2010 | 06:42 PM
  #154
RSTinOKC's Avatar
Do the OBX headers have bungs for o2 sensors? I can't tell by the pics.
Also, what are the negatives of tuning for LT's (I have shorties and catback atm) before actually installing them?
Old Jun 17, 2010 | 06:58 PM
  #155
Beatdown Z's Avatar
Laid Back
For those who don't know, these headers are down to $290 shipped! Great deal IMO.
http://cgi.ebay.com/ebaymotors/ws/eB...:MEWAX:IT#shId
Old Jun 17, 2010 | 09:24 PM
  #156
rel3rd's Avatar
11 Second Club
Yes, there's at least 6 bungs that can be used, so no extensions are needed. Screw your O2's into whatever bung that they're closest to.
The only negative I have come across is that longtubes (any brand) tend to cause the O2 sensor readings to be "slower" reacting due to being farther away from the cylinder heads. I simply "turned off" all of the slow response codes but they don't make a difference in how the truck runs anyway.
Old Jun 20, 2010 | 08:37 PM
  #157
TGriz's Avatar
just a thought but have you considered getting o2 sensor bungs welded in up stream a little to improve the readings and eliminate that code?
Old Jun 20, 2010 | 08:46 PM
  #158
Camaro Zach's Avatar
sure they "should" be, but their not... Headers are made out of tubing and not pipe. Tubing is measured by the OD and Pipe is measured by the ID. Sure it would be nice for them to be measured and advertised by the ID since that is where all the flow is but it just makes things even more confusing. Especially for anyone working in an industry that deals with OD's and ID's day in and day out.
Old Jun 21, 2010 | 02:27 PM
  #159
Former Vendor
Whether they are supposed to be or not, every Gen3/4 LSx header that has come through thsi shop has been measured OD....I just now verified this on Pacesetter, Kooks, ARH, and Dynatech headers to be sure. The only ones that varied slightly were the TSP coated headers and Pacesetters due the slight extra thickness of the coating....the stainless headers were all spot on by the OD. AND....Not only do the primaries measure correctly by the OD, so do the collectors!
Old Jun 21, 2010 | 02:29 PM
  #160
Former Vendor
Exactly! It'd be nice if that were the case (ID instead of OD), but it's not the case.
