e fan temp probe
Old Feb 2, 2007 | 11:47 PM
Default e fan temp probe
I have the flex-a-lite e fan controller part #99889. The instructions say to put the probe in the upper radiator hose. Does it really matter? Just don't want to run into a leak problem.
Old Feb 3, 2007 | 12:18 PM
cmiller's Avatar
put the probe as close to the upper radiator hose but in the radiator you push the probe through the radiator bending the cooling fins as it goes in just get as close to the upper radiator hose
Old Feb 3, 2007 | 12:30 PM
bgray's Avatar
TOTM: June 2007
yah upper hose...GEts the msot accurate temp reading...it is very important
Old Feb 5, 2007 | 11:51 AM
krambo's Avatar
Don't forget to install the little rubber cap after it is through the radiator. It is needed in order to get an accurate temp reading. Better yet is to make a harness and turn on the fans via PCM. Cleaner, more reliable.
Old Feb 5, 2007 | 04:47 PM
cmiller's Avatar
where do you get the harness and how do you hook it up to the pcm
Old Feb 5, 2007 | 07:27 PM
bgray's Avatar
TOTM: June 2007
GET it from Nelson..comes with instrutions
Downside: You ahve to have it turned on from the PCM..so you need someone to do that for you.
Old Feb 7, 2007 | 12:09 PM
Beastofa327's Avatar
I already have my efans in and running but I just wanted to know is where do you get the temp probe.
Old Feb 7, 2007 | 03:11 PM
04BlackGmc's Avatar
10 Second Club
i like my flex a lite kit.
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
