blackbear harness install issues.
Old Sep 26, 2010 | 12:49 PM
AndyJ_o's Avatar
Default blackbear harness install issues.
so heres the deal, right now im attempting to install my LS1 fans along with a blackbear harness. when i throw the key to the ON position the passenger side fans comes on high. it doesnt matter if the AC is on or not it just stays on high. the engine takes a super long time to get to operating temp and the drivers side doesnt even get the chance to come on. i know the drivers side works because i switched the plugs with the pass and drivers to check. originally i thought my connection to pin 42 was insufficient so i took it out, lengthened the wire and then soldered a bunch of it cleanly to give it some rigidity so i could push it into position. all my other connections are as follows; lime green wire going up into the fuse panel and connected to the 12v AC wire which is about the same color and size, one ground to the alt bracket, one ground to the batt, and the power to the junction box next to the alt bracket.
i cant seem to figure out whats wrong with the circuit. could it be possible that a relay is bad? i really need some help here guys!
Old Sep 26, 2010 | 01:15 PM
02'Z71ONDUBZ''s Avatar
I bet you spliced into the wrong green wire on the harness for the AC trigger. There's more than one green wire in that loom. Try the other and see if that fixes your problems.
Old Sep 26, 2010 | 02:43 PM
jadaven's Avatar
So I'm going to hijack this thread to not create a new e-fan thread. What would cause both fans to run only? LS1 fans with the Blackbear harness.
Hits OP temp, at idle both fans come on. Cools engine temp and the fans go off.
I haven't had a single fan come on by itself (that I know of). When would/should it run on a single fan only?
Old Sep 27, 2010 | 05:59 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe you don't have the right ac wire?
AC compressor clutch engaged while engine is not up to turn on temp will cause one fan to come on high (with "1 pin" harness)
Old Sep 27, 2010 | 06:55 PM
What temp do you have the fans set to come on at? Do you have a single or dual pin harness? Are they both on low or high?
Old Sep 27, 2010 | 11:11 PM
AndyJ_o's Avatar
got it all figured out. was tapped into the wrong ac wire. the correct AC tap is the dark green wire. im so glad i got these working
Old Sep 28, 2010 | 06:13 AM
jadaven's Avatar
2 pin Harness, I have no Idea on the temp setting, I'm guessing they are on low.
I didn't do any of the programming so I'm waiting on an email back from Justin.
Old Sep 30, 2010 | 08:10 AM
jadaven's Avatar
Did get a hold of Justin. They either don't run, both run on low or both run on high.
Old Sep 30, 2010 | 11:14 AM
budhayes3's Avatar
PT's Slowest Truck
Ahhh, OK, that's different than my Nelson 1 pin harness is set up...
zblee
63
Jun 10, 2023 01:25 PM
ARC
57
Feb 21, 2022 10:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
mr03silverado
Jul 17, 2015 02:15 PM
