THE Tru-Cool 40K GVW Transmission Cooler Install Thread
Old Mar 18, 2012 | 11:35 AM
  #181
chevrolade's Avatar
Just ordered my Tru cool shall see if it helps the 6l90e before removal I was hitting 240 just at idle in line at the track but it'd fine at 160 on the highway , I will definitely put it to the test . Will be back with my results. Great thread
Old Mar 18, 2012 | 08:18 PM
  #182
48548's Avatar
Do they make brackets for the nnbs 6l80e yet? I want to install one as well.
Old Mar 18, 2012 | 09:47 PM
  #183
Velocity1's Avatar
Originally Posted by Velocity1
I too read the entire post. Most informative I must say!
I live here in the Northern part of the Mid-Atlantic where temps. soar to the 90's in summer and get quite cold in the winter @ 20-30 degrees.
I'm preparing to install the CD 278mm 3000 convertor, Hypertech 180 degree thermostadt and Dearle +2 qt. trans pan with temp. gauge in my '00 Silverado.
I already have the TransGo HD2 kit and Sonnax billet servos installed. Tires are 32" and gearing is 4.56. Trans is 4l60e.
Would I be better off to bypass the radiator all together or plumb the Tru Cool 40K in series with the return line to the trans?
If I bypass the radiator all together, There's no need to plug the trans cooling line in and out fittings @ the radiator?
I didn't really see where this was discussed, (I don't think), other than I recall someone said to just leave them open. If I wanted to plug them, what would I use?
Thanks for the feedback. I want to get this right.
V1
I've decided to plumb the Tru Cool in series with the factory cooler on the return line. Which side of the radiator is the return line? Does anyone have the "short list" of fittings needed to accomplish this without altering the factory metal line? I plan to use high grade push lock hose and fittings along with the Dearle deep, (+2qt pan) and mechanical temp. gauge.
I can't remember for sure when I read the 40K install post, but does someone offer pre fabricated brackets to help simplify the cooler install?
Thanks, V1
Thanks.
Old May 11, 2012 | 09:28 PM
  #184
pewterliftedz's Avatar
What size are the transmission cooler lines? I need togo purchase a compression fitting.
Old May 22, 2012 | 11:14 PM
  #185
subsribed
Old Jun 18, 2012 | 05:30 PM
  #186
rjwz28's Avatar
Man Motor club
Damn. Nice thread; subscribed. Any updates on GMT900s? I have an aux trans cooler and want to upgrade, and I'm looking for the most simple way to swap them (without using rubber hoses and clamps to tie to the stock hard lines and a board for a mounting bracket )
Old Jun 24, 2012 | 08:31 AM
  #187
SloStepSide's Avatar
Really don't feel like reading this whole thread again, but what is the members name that has the nbs brackets the the trucool?
Old Aug 4, 2012 | 05:10 PM
  #188
RibeiroBJJ's Avatar
Praise The Lowered
Bump..when bypassing the radiator, do you need to close up the holes left by not using the integrated cooler?
Old Aug 4, 2012 | 09:22 PM
  #189
1BadAction's Avatar
Registered abuser
I would, for the sole reason that if you ever want to use it again, you will not need to worry about how much dirt and road grime has made it's way in there.
Old Aug 5, 2012 | 10:32 AM
  #190
RibeiroBJJ's Avatar
Praise The Lowered
Yeah, I just crimped and tig'd the ends up..The little snap rings were a pain
