THE Tru-Cool 40K GVW Transmission Cooler Install Thread
#171
Sorry, I'm somewhat confused on the stock lines that run into the radiator also. First off, how do you remove these lines? Should I even remove them? I have SS hose running to the transmission so these lines are just dangling under the truck right now. If anybody could clarify this a little more for me I would really appreciate it.
Thanks
Thanks
#172
Thanks
Thanks
#173
I guess unhooking the lines is my confusion. I am not using them for the installation since I ran braided stainless hose all the way from the tranny to the cooler. So I currently have the radiator lines still hooked up at the radiator, but dangling in the back of the truck. I tried unhooking them from the radiator, but couldnt figure it out. Maybe it's something super easy and I'm just being stupid, but I kept looking and couldn't get it.
#174
They are held in my E clips. You need a small flathead to POP them out then just pull the line straight out. Watch out because they go flying. Don't try unbolting the fitting, you'll crack the rad.
#177
Just wanted to check back in and say thanks again for the help. I got the original hardlines out this evening and feel kind of stupid for even having to ask how to remove them. They were super easy! Now I don't have to worry about the damn things dangling around while I'm driving..
#180
I too read the entire post. Most informative I must say!
I live here in the Northern part of the Mid-Atlantic where temps. soar to the 90's in summer and get quite cold in the winter @ 20-30 degrees.
I'm preparing to install the CD 278mm 3000 convertor, Hypertech 180 degree thermostadt and Dearle +2 qt. trans pan with temp. gauge in my '00 Silverado.
I already have the TransGo HD2 kit and Sonnax billet servos installed. Tires are 32" and gearing is 4.56. Trans is 4l60e.
Would I be better off to bypass the radiator all together or plumb the Tru Cool 40K in series with the return line to the trans?
If I bypass the radiator all together, There's no need to plug the trans cooling line in and out fittings @ the radiator?
I didn't really see where this was discussed, (I don't think), other than I recall someone said to just leave them open. If I wanted to plug them, what would I use?
Thanks for the feedback. I want to get this right.
V1
V1
