THE Tru-Cool 40K GVW Transmission Cooler Install Thread
Old Jun 18, 2025 | 03:55 PM
  #321
Grzmny's Avatar
Originally Posted by F5Sierra
You can and probably should bypass the radiator cooler. It will run cooler staying away from that. And, where you live that will never be an issue.
That’s what I was thinking is to bypass the radiator completely but I went through all 32 pages and about half of them say to run it through the radiator first to take away majority of the heat. I don’t toe with it. I just have bigger tires and a very tall gear.
Old Jun 19, 2025 | 12:07 PM
  #322
therock's Avatar
I want it all. I just routed the lines to and from the OE trans cooler through the tru-cool keeping the radiator in the mix.
Old Dec 20, 2025 | 09:10 PM
  #323
mizzac's Avatar
I likely missed it and im fairly green in this area, but reading this thread, simply put, is there any reason to now just connect to the existing factory lines or is really worth it to run the full stainless GAP kit back to the transmission? I have the stainless GAP kit but i can't see the benefit to keep s fill rerun vs the stock lines and some hose to the tru cool
Old Dec 21, 2025 | 12:50 PM
  #324
therock's Avatar
I removed the OE cooler and adapted onto those lines. No issues or regrets.
Old Dec 22, 2025 | 07:10 AM
  #325
Earl Cordova's Avatar
I have done the same thing on two trucks and glad I did it.
Old Jan 3, 2026 | 07:08 PM
  #326
mizzac's Avatar
do you have photos of how you ran the lines back to your radiator?
Or does anyone? The instructions on here to say use one adaptor at the bottom of the radiator but thats not the correct tie in or size so im a little confused.
Old Jan 4, 2026 | 04:20 AM
  #327
smokinlmm's Avatar
I had my radiator bypassed and you can’t get the trans warm in the winter. I had mine rerouted back thru like stock and the trans temps stay right around 150 all the time in summer and around 135 in the winter. I used to have a piece of card board I painted black to cover up 80% of the cooler to keep temps over 100 degrees. If you live in a cooler climate I’d keep the factory routing.
Yukon04
Aug 30, 2013 01:47 AM
kpanza
Oct 13, 2012 11:47 PM
SmokinHot98
Oct 9, 2010 10:12 AM
blown 04
Jul 21, 2010 11:34 AM
02_2500avalanche
Oct 15, 2008 10:00 AM
